I picked up a Dlux Portal transmission and driveshafts when they first came out and was looking for a home for them along with some Capra axles. For some reason I totally glossed over the Asylum being exactly what I was building lol
Anyway I finally figured that out last month and I've been assembling one as I get parts.
I found a vintage set of RCP glue on wheels, surprisingly they still have a few sets in stock. These do not clear the Capra axles with a 650 SLW without a bit of clearancing the top of the portal boxes. I also grabbed a pair of the Dlux Goat tires (medium compound) for the front and a pair of the PL Ibex tires (G8 ) for the rear.
Because of the Radioactive symbol look to the wheels I decided to add some color to the chassis and ordered it in lime green with a green skid and aluminum shocks (since the green shocks are a totally different color green). Typically I just go with muted or no colors lol
I went with the 80mm shocks. They also list a 96mm shock option but im pretty sure that will just be a headache clearance wise as the 80mm shocks barely clear.
I had to do a bit of searching to find a battery skinny enough to fit the battery tray. luckily Gens ace/Tattu has one (TAT-45C-450-3S1P-JST)
I swapped the JST connectors for XT30's and I made a slightly longer version battery tray so that I dont wear out/rip the balance lead which ends up at the bottom of the tray. It will fit in the stock battery tray but I wanted some wiggle room to be safe.
The body is from Mcallister racing https://mcallisterracing.com/shop/ols/products/240-vintage-modified-coupe-body
This is an old pic before I fully trimmed the body to fit. The lexan is super thin on this body but its light.
I ordered some Traxxas paint to try it out, they have a fluorescent green that should suit the theme. Oh and the cans are bigger than Tamiya's which is pretty awesome theres even a full sized can in some colors.
More updates to come "thumbsup"
