Questions, suggestions and contact information
I'm looking for a set of 1.9 to retain factory track width on wraith axles. I though I saw something that said the hex wheels retain the same width as .185 slw hubs you guys offer? Can you point me in the right direction to either setups that will offer me the factory track width or shorter for the wraith
I don't have a stock Wraith wheel here to measure, but if you do, you should be able to determine the difference in width of our 1.9s as well as any change in backspacing:
http://www.lockeduprc.net/19wheels/8lbackspace.jpg
http://www.lockeduprc.net/19wheels/slwbackspace.jpg
For the 1.9's ...SLW setup with .185 and 8L will be as close to a stock Axial wheel as you can get (backspacing and width)... but that's an Axial 1.9.
If you are going from a 2.2 to a 1.9 things can change a bit because of the general width change of a 2.2 to a 1.9.
So the best thing you can do is just pull a few measurements for yourself. If you want to share what you come up with I'm happy to help you interpret the data!
"thumbsup"
These aren't really suggestions, more stuff I could use, or want.
0-80x3/16 scale hardware. (VP lightbars)
2.5x??mm scale hardware. (Motoworx 2.8" wheels)
Flat washers with the same tight tolerance as the cone washers.
Oh, before I forget, the JDUB in 1.9" would be sweet.
Backspace is roughly 1 inch, from hub to lip is about 5/8
Sorry I missed this!
The backspacing on our 8L is 14mm, but our wheels are also a lot narrower at 25mm ...I seem to recall stockers being really wide.
How wide are those wheels?
JDUBs are on the list for sure and I'm sure we can come up with some washers.
The other scale hardware will take some time. We are looking at adding more M3 before getting into other sizes but I will add those to the list. "thumbsup"
Man, I should've made this part of my previous post, and I suppose this ones a suggestion, or I just want them.
I'd like to see a slipper eliminator for the vaterra ascender transmission input shaft, maybe two versions. One for RRP1558, and one for both RRP7086,and RRP7076.
I bought one to try and see if I could use it to move to an RRP1558 32p spur gear on my ascender, but the keyed hole that the eliminator has machined into the centre is slightly too big for the keyed input shaft on the ascenders transmission.
Hmmm ....
We'd need a test Vaterra....:twisted:
Any info if you will be selling more 1.9 wheels in black?
We are going to rework the machining process to minimize the amount of blemishes we get during anodizing ... and we have a bunch of new items coming out before we can get to that.
So it will be a little while, but you can expect to see some more black wheels in the future.
"thumbsup"
I have a suggestion it would be to include some locked up stickers with stuff u sale
We actually used to but people requested for us to not do so in order to make individual orders cheaper.
So as it is currently, people that want stickers can get them, and the guys that need to save money can. "thumbsup"
HD 3mm socket driver please. "thumbsup"
I got to use my new HD 2mm socket driver the other day and it is fantastic. Can't wait to add to the collection.
