winnerone23
There is a electronics thread on the main menu.. that's where I head for electronic questions, plus post them here..
i tried that and it blinked all of them with a audible tone a few times then the fourth one by it self a few times then the last one and it just kept going til i turned it off! but it would do this last night when i would hold just the mode button down by itself! im not doubting you but the manual says hold down the INCR button for self test and it doesnt do any thing so when i hold both down and it reacts the same as just holding down the MODE button that makes me think that maybe the INCR button is messed up or doesnt work! idk thats just a theory but this is depressing! is there a tekin fxr specific thread somewhere on here!
You could order it now an have it shipped home.. remember ur 1.. 2.. 3... Lol better add, 0.5.. fix what's broke.. then get back to 1.. the pop, may just be ur drive shaft.. the set screw may have backed out just a touch.. I had the same issue once. As soon as I changed my drive shaft out... It was gone.
ya i agree with winner check your drive shaft set screw also if you can find the pin for the axle you should be able to slid it back in then put some heat shrink tubing around to keep it from falling out till you can get some pin locks just my suggestion
so if my front drive shaft keeps slipping off the axle, i should get a new drive shaft
Dog 13.. I had the problem an had new traxxas yokes an long shafts that showed up, so instead of tightening down the set screw I just changed my shaft an yokes all together.. I put the set screws in with blue loc- tite an let them sit over night, it will be better when you wake up.
I dont have any luck using blue lock tite, red is a must imo.
is it loc tite brand? I used green once not a good idea ask Thomas lol:lmao:
I use Permatex high strength red. I use red for all driveline parts and blue for all other metal to metal.
Lol, I can only imagine how fun it was to get the screws out using green....that's torch time...!
