proline two stage foams
rigcheck
Manchester
hello everyone been here a while now long time lurker lol. anyhoo ive purchased an Axial scx6 Honcho also some dual stage foams and Hyrax tires , the outer white foam moves about on the blue part. has anyone glued them together or is it part of the way theyre supposed to work? thanks for any advice solutions in advance guys
The outer stage is normally separate from the inner stage. It also makes it fairly easy to install since you can separate the pieces and stuff them into the tire individually.
You're fine to bond them together if that's what you're wanting to do. Just use a flexible adhesive like e6000 or shoegoo. I wouldn't use a ton of it.. just a single bead or a few spots all along the circumference.
