Projects
Got some fresh panels on the berg.
Is that your Berg? :shock: When did you make the switch? From a Thing to a Rockshow and from XR to Berg?
Just curious why all the changes?
Looks great by the way!!
Are you still on white dot blocks or reds now?
He just needed a change...the XR wasn't doing what he wanted. The berg was actually easleycrawlers. We worked out a trade to get him all the parts he needed for his scaler. The switch started a couple months ago. He's still running the white dot blocks...they seem to work well on most rocks, but they do prefer a softer foam setup. He's currently running a single stage front and a closed cell inner and medium outer in the rear I believe.
I threw the CCD tubes on the front and he swapped out to big bores, and that's about all that's changed other than the knuckle weights since Travis had it. Oh yeah...he was running dual BRXL's in the XR which we kept, but one of them was having an issue so right now he's running the sidewinder micro pro for the front and the BRXL for the rear. This is just until the BRXL gets replaced.
What Ryan said. I had been running the XR for over a year and had some success with but I just decided to switch things up. No real major reasoning behind it. I still have a XR that I am working on as well."thumbsup"
X2 because at the last comp I asked Sterling when he was going to get him a scaler for the G6 and said he just wasn't into scalers :mrgreen: :roll: "thumbsup"
But I hope to see it at the comp 8)
