skerb
the pulling sled is painted and re-assembled[/IMG]![]()
Looks great Bill!
Sent from my DROIDX
here is a video of the sled in action Axial scx10 pull truck sled - YouTube
Looks cool...curious though if it couldn't use more of a ramp at the leading edge to keep it from catching too hard on stones and such during the pull.
Good point.
Sent from me using my DNA
Its meant to be run in soft dirt/sand. The sharp edge helps plow when the weight moves to the front. At least thats what i have seen from other rc sled pull comps.
Sent from my DROIDX
Ok...so you're always going to have a nice smooth surface in soft dirt and sand? Don't think so.
Check these out...
i made it based off of the pulling sleds that i use to pull when i was doing real tractor pulls back home in Ill. the wide skid with the flat front digs in more and requires less weight to carried in the box, when i tested it rocks on the surface seemed to have little affect on the sled. we will have to rake the the surface we are running on though to keep it the sameRight on...wasn't saying it "had" to be changed, but seems like it would make it easier to use it at different locations without having to do nearly as much prep work. Maybe ya'll are different, but the drivers at most events I've attended or put on haven't wanted to drive 1-3 hours to spend another 1-2 hours getting the place ready to use.
I have little to no interest in running scalers, pullers, etc. so I was just offering the suggestion. No worries either way 8)
did that t-case clear all right? looks great
