Traulus
can i have the ebay link?ordering from vanquish webpage is a killer.shipping its to much
Hmmm mine mounted up no problem. It was a little difficult getting the bolts started but once they did it went together fine.
Sent from my SM-G920V using Tapatalk
What Chinese beadlocks were you using? I have mounted a set of Hyraxes to some and a set of VP Bully wheels and didnt really have a problem. Just get everything lined up, put pressure straight down on the ring, and start a screw a couple turns, then start one 180 degrees away from it and slowly tighten all the screws in a star pattern.
If it is a set of the RC4WD knockoffs, it would likely be a different story though.
I will let yall know when I get my new Pro Line 2 Stage foams for the Hyrax's if it changes the ease of mounting. Going to attempt to mount them to my new RC4WD Wheels first as those where the ones giving me troubles with stock foams.
Oh! Wow! Ok, didn't realize you are in Romania.
Here's the ebay link... Vanquish VPS08106 SCX10-II TRANSMISSION TOP SHAFT | eBay
You can search for that part number and find other sellers that might be closer to you.
are you using stock chubs and knuckles?
