Ok so my Wertymade stuff showed up today. As well as my Pit Bull A/T tires. I want to make this into a class 1 rig for comps for next season. I was really surprised about how the tires looked. They are not that much shorter but they are definitely narrower.
Side shot, you can see the stock BFG is just a bit taller.
Here you can see how much more narrow they are. They look narrow enough to where I can probably put the TF LWB hardbody on the chassis and they wont stick out too much. Now I am not sure if I want to go with the XJ hard body or the Hilux.
I guess these look more scale as a daily driver. I am guessing these are closer to 39-40" tires in terms of looks.
Now as for the bumpers. I am not sure if maybe I installed them wrong or if maybe he has changed his design just a little bit to make an easier install. But after looking at them for a minute I came up with a less elegant solution. I don't have any aluminum laying around and machining is not in my background but this is what I did.
I put the screw in the last hole in the mounting plate and screwed it into the existing cross member. It fit and is tight enough that its not moving. I plan on running it tomorrow to see how it works.
I might need to trim the body just a bit where they spacers are so it sits perfect every time but I thought it looked really good! If you don't set the body on just right it kind of bunches up, thats why I suggest trimming just a bit.
The front was about the same (I forgot to take a photo after I installed it with the body off). I mounted it jus the same as the rear but tucked it in one hole since I don't have a winch yet. Bracket around the chassis frame and into the existing cross members. I think it looks good!
Ready for tomorrow!
Using a piece of cardboard as a guide I noticed it has a much nicer approach angle. I cant wait to try it out tomorrow. I will post action shots tomorrow and maybe try to shoot a little video.
-M
