un-fawkin'-believable
i bolted up the AXI outrunner and took it for a test spin. first i discovered my XR3i doesn't speak airplane language, so i couldn't change the settings on the ESC, and had to reverse the throttle in order for anything to work at all. this of course will be remedied with a car ESC if i go ahead with the project.
the settings i had were, 4.0 cutoff voltage (which never cut in), very sensitive current limiting, which shut down the motor in stall situations to avoid blowing my borrowed ESC (not a bad thing considering), soft, delayed brake (still very effective), auto calibrating throttle (whatever that is, it was still backwards), high advance timing for more power, less efficiency, hard cutoff at low voltage or over-current, and very soft start (for use with fragile gearboxes, which the E-Maxx box ain't).
less than ideal settings, but with no way to change them, i set out anyway.
first test, extended grass bash: tooling along in second gear over the grass and weeds, no problems whatsoever. motor barely warm, ESC a little warmer. grade: A
second test: climbing plywood. this was an attempt to stall the motor so i left it in second. plywood at a 45 degree angle. the "very soft start" hampered me here. starting on level ground, it would go right up, never slowing down. starting on an incline, the motor would struggle til it got a couple revs in, then went right up. in first gear, no problem. right on up. motor a little warm but not oncomfortable to touch, esc a bit hotter. grade: B+ (allowing for soft start troubles)
third test: actual rocks. again hampered by the soft start, but if the truck slid backwards and got the wheels turning, the motor kicked in and blasted away. lack of reverse and a backwards throttle didn't help, and the body was off so i could check temps, so this wasn't a great crawl. however, the motor did well, except for stalling due to the damned soft start. motor warm but not hot, esc kinda hot. grade: B
fourth test: flat out torture. hold the truck down and give it throttle. the diff chattered before the motor stalled so i will have to say grade A
speed was similar to the EVX/Titan combo. a bit faster than walking in 2nd gear, slow as hell in first.
since all the issues i had were with the programming, and not the motor, i think i will go ahead with this, using a Mamba-25 ESC and a similar motor to the one tested.
i was flat-out stunned at how well this dinky-azz motor performed. i'm looking forward to doing the upgrade permanently.
anyone want to buy a modded EVX and a Titan?
