OS's SWB Yeti with trans swap
Run number 2... swapped in some old Traxxas electronics and did some more tweaks.
Decent flex... I'm only running 25wt oil and stiffish springs, so it's a bit flexy and bouncy - really works well with the front and rear swaybars though and makes for a somewhat active suspension.
Fantastic sidehill... COG is quite low, the motor actually sits below the level of the tops of the tires. Makes for a super stable truck.
Low and lean... Not a ton of belly clearance, but enough for most situations so far. Can always jack up the suspension a bit if needed, but I like the low stance.
Climbs like a bear...
And just enough speed to make bombing around the fields fun!
Just a few chassis pics... Stock TRX electronics for now just to get a feel for the chassis and if it was worth it to upgrade. Since it seems to work well, definitely looking for an upgrade here eventually.
Got the crawler Yeti out to play. I had a ball with it, putting the 3 gear trans in changes the whole feel of the truck. Lowers the COG a ton and puts the gear ratio right in the crawler zone. Before leaving, I realized the motor was running reversed timing and that wasn't good so I swapped in a Holmes 21t Trailmaster - problem solved! Crammed in 1.5oz of lead weights in the front of the chassis too to add some front bias. We went out along a dry lakebed and while the terrain wasn't too challenging, but there were a few cool spots where the Yeti got to crawl around on and a good first test run.
Nature is awesome - check out the tree! Normally this is underwater.
Another cool tree!
Lots of rip-rap type rocks...odd, it's like shale rock but sideways. Really neat and grippy.
Low and slow. The suspension was great, it was fun watching the IFS work and rear axle twisting around as it snaked over stuff. The COG is ridiculously low, it's like a rock spider and so stable I never flipped it all day. Might look into a slightly thicker front swaybar to help front clearance in certain situations but it was pretty dialed already.
Definitely worthy of some better electronics... the Traxxas ESC and survo actually did fine though 4 hours of wheeling - even the steering was decent though it could use some more power for sure. Motor-wise, the Trailmaster was great as always and perfect for a big heavy rig.
I've considered switching my Yeti to a more crawlery type set up, I have a spare Holmes 550 can motor and ESC, with a decent Savox already in it.
Sadly the pictures earlier on in the thread are no longer showing so it's not easy to follow along since I work better from visual rather than text.
Just rebuilding my Yeti currently too, if it still doesn't run how I want after this rebuild, I might consider a brushed system, I also have a 3 gear trans sat here with 2 speed already installed.
May have to 'borrow' your idea lol.
Wasn't much to see really, looks pretty much the same as it does now. Lined up the transmission with an existing hole in the chassis and drilled the other three IIRC. I did use a dremel to remove the webbing in the chassis so the trans would sit flush. I think I had to trim a bit here and there for the 550, though a 540 can might fit without it.
Do it! This truck is very capable, very glad I hacked it up. :)
