OSRC
I picked up a Yeti Score kit a few years ago, and it was a fun build. However, driving left a bit to be desired... The dump truck handling turned me off, the nosediving off jumps ripped the front bumper off after 2 battery packs, and it sat on a shelf after 2 outings.
Then I converted it to a standard Yeti... Added 2.2's and reworked the suspension. Still not happy with the handling, it's been on the shelf since.
Pulled it off the shelf and decided to give it one last go. With some tweaks of course...
Times for some mods and changes....
Here's where I started. Tires removed, dusty and unloved. Loved the look, just wish the performance matched.
Got a good base to start with, I added quite a bit of hop ups when building it up.
Original plan was to move over to an Exo chassis and build off that...
Scrapped that idea, and decided to work with the stock chassis. broke out the dremel and started hacking.
and boom! SCX trans installed.
Differences to the COG is obvious when side by side with the stock trans. Can even feel the difference just handling it.
Have to do a bit of trimming to the battery box. I wanted to leave plenty of room for a 550 so the trans is back pretty far.
Whoops! trimmed a bit too much and took off one of the bosses for the front brace. This was more of an experiment...I've got another chassis here I'll do a bit cleaner later on.
Shortened the rear suspension with Twin Hammers arms while I was at it. Figured this would help with weight balance (the Yeti is way nose heavy) plus I like the look..
New chassis layout
Went back to the stock Yeti body and cage for now, along with the TT tires. I like it, kind of has a Polaris Razr vibe to it. May invest in a new body later if I can get this thing dialed.
More to come..
New chassis layout
More to come..
