Danger Dookie
Installed a CC external on my Wraith.
I forgot to pre-program the BEC to 7.4v. I have already soldered the power lines to the lines for the servo (7950hitec). I tried to connect CC Link to the BEC just using the data wire and powered the BEC using the battery. CC Link would not recognize the BEC. I believe it needs to have power connected to the BEC to verify what it's setting.
I'm not the best at soldering so I'm reluctant to cut wires, put on a new plug and set the BEC, then re-solder.
I have thought of a few "work around" and wanted to see if someone more knowledgeable would be able to tell if any of them would work.
1. Connect the power lines from a second BEC to the link but use the data wire for the BEC I'm trying to set.
My idea is that the link will see the "bec" power wires but will send the data to the BEC I'm trying to set..
2. Take a spare wire and touch it to the power wires that I had soldered to the servo lines.
I had worked slowly on the kit and then rushed into the end as I got excited. Currently the rig works fine but I wanted to set the BEC to 7.4 for my 7950.
Thank you for your time!
