very cool, been waiting for some offset tubes. are these at all useable with the diff on the passenger (right) side? links would have to be in single shear, but are a decent pinion angle and caster even possible...?
No you cant mirror these tubes. Would need new tubes. The issue with passenger side version is the panhard clearance on the pumpkin.
You wanted this right?: Trail King Diamond Offset Front Axle Case
Ok cool cool.You mirrored everything so you dont have the issue. I was talking about having the pumpkin on the passenger side on a Trail King/SCX10 II platform. Then the panhard bar clearance will be an issue.
How about some tubes and axles to narrow the width down.
That would not be a cheap option: tubes, shafts and steering links.
I was looking through the SSD-RC site and chanced upon this and the new DIamond Offset axles. Then it said, not compatible with the old scale transmission.
Why so? Is it about the gearing? or the placement of the upper link on the driver side?
I was under the impression that the old scale transmission would work for both the SSD D60 and the Pro44 axles.
