XSRCdesign
Are you going to come out with a fixed version then?
Pretty sure he said multiple times now they are updating the tooling
So, If you plan on just driving your truck in a straight line. Tape will work great.
If you actually plan on going hard, Comping, Doing real driving, Think about other ideas...
People need to quit trying to sweep this issue under the rug like its nbd.. Thats exactly how companies get away with crap..
Also, if thats the rear you are trying to show off. you are cheating..
The rear doesn't see NEARLY as much stress as the front..
Try turning your steering past 70*, See what I'm talking about.
No, i don't have 70* of steering and I don't comp all the time. I should be ashamed. You obviously win at toy trucks.
Well you saying you are the one that posted a video ( which I thanked you for , you probably skimmed over that )
I was the FIRST person to post on the issue.. Go back and look, I can wait..
In that same post I also said that foil, and tape , etc were only temp fixes, and not good for long term HARD driving..
On the winning part, The truck that had issue after issue with SSD D60s , Thats now running SSD diamond on both front and rear..
It's in progress. It takes time to update tooling, test samples, and make new production.
When these were made nobody was complaining about needing larger bearings in the SCX10 axle otherwise we would have.
This thread his gotten incredibly hostile
Agreed! It's a pity. I think the RC hobby, like everything else, is an ever developing thing and nothing is perfect. Not even the SSD axle housings. But I am generally very happy with my SSD purchases. When the axle housing is driven to destruction, try another brand next time if you are not happy with it.This thread his gotten incredibly hostile
My bad.
Let me just reiterate, so it's not lost, that different people enjoy the hobby in different ways. If you enjoy trail driving and already own these great looking axles and want to run them, the aluminum tape work around may be worth trying to extend the life of your gears. Time will tell.
If your primary involvement in the hobby is comping, you may want to go back to try a different axle housing.
Either way, I think we're all looking forward to a revised housing.
Agreed. I see these and think scale. Run OGs with tubes and XR mod or Stage 1, or some other comp designed axles for comp.Well said. Love my ssd axles but I fall into the former category. I'm not excusing what has obviously been documented as a huge flaw. With that being said. I'm not sure these axles are a great choice for hardcore comping anyways.
I'm a newbie to this and I wonder about the ssd aluminum diamond axles - are they good for comp or hard bashing or mostly scale?Agreed. I see these and think scale. Run OGs with tubes and XR mod or Stage 1, or some other comp designed axles for comp.
Sent from my XT1585 using Tapatalk
Sent from my SM-G930F using Tapatalk
Yeah, I think we kinda know that already. I have six axle housings, the outer bearing is too small for the provided space. We all know that by now..I've been working on my Deadbolt that is currently running SSD D60 housings. I haven't run them hard or that much and both front and rear have slop in the pinion bearing bore. Guess I'm going back to stock housings. I'll keep an eye out for solutions.
I believe this was discussed earlier in the thread but a standard size bearing wouldn't fit because the opening is slightly too big for a stock one but still to small for the next larger size.I have two of these axles sitting in the bags cause I came across these posts before building them, so I'm kind of just tossing it out there... Would a larger OD bearing fix the issue? I know they were supposed to reuse stock hardware, but does SSD need to reinvent the wheel here?
Ah, ok, I missed that then, thanks for the clarification.I believe this was discussed earlier in the thread but a standard size bearing wouldn't fit because the opening is slightly too big for a stock one but still to small for the next larger size.
Sent from my SM-G920T using Tapatalk
