stillsmokin875
Man, looks like an amazing spot to crawl, ever run into any snakes on those rock formations? :???:
I wish i had a spot like that close by
Cool truck mate......now lets see those shut lines;-)
Man that spot looks great!.Your ascender looks just like mine.Any plans for an interior?
OK, I didn't find a single thread but bits & pieces here & there.
For "standard sized" servos (Futaba 7955 as an example) (1.57" x 0.79" x 1.50" or for the rest of the world 40mm x 20mm x 38mm), the below is a guide on spline count.
23 splines: KO, Airtronics/Sanwa, JR, ACOMS, Solar, EXI.
24 splines: HiTec, RCD, Apollo (plus some Tower/Hobbico as HiTec makes them)
25 splines: Futaba (newer), Savox, (plus some Tower/Hobbico as Futaba makes them), traxxas 2075 digital waterproof servo, HPI, HobbyKing-BlueBird, some TowerPro [mg995], RC4WD
SOME INFO FROM SERVOCITY (11/3/2013)
Hitec Servo Splines
Futaba Servo Splines
The micro/mini servos are different, thus servos used for shafty dig units, servo digs (for MOA's) and MRC steering is a seperate issue.
If you find a correction, or want to add, feel free to do so.8)
Note: some of this came from here.... RC Groups - View Single Post - expert servo arms
"Servo Database"...... 1st page is so-so, click on the brand you're looking for at the top of the page for more info on that brand... Servo Database - RC Servo Specs and Reviews
The kit comes with a 23,24, and 25 spline servo horn so I'm sure you could order a new plastic one with your preferred setup if you wanted to and didn't want the aluminium one.Not many choices for 23 spline servo might have to change that...
I'll stick to the common 25 spline...
Ya look like the taper part of the bumper should be facing the sky"up"'Looks out of place now the i look at it.Just a quick flip should do the trick.Somebody at Horizon Hobby put it the wrong way maybe ,I'll have to check out the picture threads to see if they are all like that..."thumbsup"
Next time if you see or hear "Rustneversleeps First Ascender" it may be me.
Thanks for the updates and the quality and control in this journey..."thumbsup"
:shock: mine came only with one :xThe kit comes with a 23,24, and 25 spline servo horn so I'm sure you could order a new plastic one with your preferred setup if you wanted to and didn't want the aluminium one.
Awesome pics BTW.
So did i, but only one hornI got the kit not the rtr. The kit comes with 3 options for the servo horn. Or at least mone did
Hmm wounder if it was because i had one of the first run of kits? I got mine in December.So did i, but only one horn
Sent from my SM-G355M using Tapatalk
