Need to get some more pics up, love this Blazer body with the molded grill and lights, it looks even better now that I took the time to put the little black decals in the grill. I was going to do a wash with some flat black model paint, but I didn't have any and the sticker sheet was sitting on my bench.
I lowered the body two body post holes front and rear, trimmed 1/4" off front and rear of body, the sides still have about another 1/4" between them and nerf bars. It looks way better and I could go down one more hole front and rear on the mounts, I've already trimmed the front and rear of the wheel openings to clear the stock tires with the body lowered. Only trimmed off about 1/8" at front and rear edges of wheel wells to clear with lowered body, I think the body looks pretty good at this height, but am tempted to go one hole lower front and rear...leaving as is for now and we'll see. It's easy to cut more, difficult to put it back. I might trim the front wheel openings at the tops to clear during full flex travel and turning as it still has very minor occasion rubbing there and I like the look of the body. Vaterra TSL listed as 4.5" tall, but I haven't measured them.
Stock plastic servo horn and servo are hanging in there, but I have spare Hitec HS7955-TG servo (survived my Wraith, but wanted more power there) left over and it's now my official Ascender backup for if stocker dies. Crawled again the other night, need to get some headlights and rock lights on this.
I've been beating mine hard too and so far everything has been fine. Even did some forward reverse throttle the other day, just to see if the diffs would blow and it's still on original set of HD gears and driveshafts. Also been letting it hop and bounce on steep climbs, steering full lock in both directions, some tumbles mostly on 2S, but some 3S too, mine is all stock still. I checked diffs and had to re-shim them properly and added one shim of my own per diff. Two shims on ring gear side of spool and one shim on the other end of the spool, extra little spot of grease and that's it.
