Bought a tiny Traxxas TRX4M Bronco turk when they firs released and am very impressed with the great looking hardbody and it's crawlability! I love red, but went with blue for a change, might pickup a second Bronco body in red to swap back and forth.
Mods done one at a time to verify results.
Traxxas Compatible TRX-4M 1/18 Land Rover Defender Sealed Bearing Kit
https://www.fasteddybearings.com/traxxas-trx-4m-1-18-land-rover-defender-sealed-bearing-kit/
Traxxas steel link set #9749
https://traxxas.com/products/parts/9749
Servo mount, 6061-T6 aluminum (dark titanium-anodized) #9739
https://traxxas.com/products/parts/9739-GRAY
Servo horn (metal) #9740
https://traxxas.com/products/parts/9740
Servo, sub-micro, waterproof, metal gear #2065R
https://traxxas.com/products/parts/2065R
TRX-4M® Bronco Pro Scale™ Light Set #9783, removed the factory bumper lights and mounted one in each bumper mount as rock lights. Had to separate wiring harness a little, then drilled holes that were slightly snug fitting for the LEDS and pressed them into place with little screwdriver, then painted them red.
https://traxxas.com/products/parts/9783
Heat sink, Titan® 87T motor (6061-T6 aluminum, blue-anodized) #9793
https://traxxas.com/products/parts/9793-BLUE
INJORA 180 PRO Brushed 48T Purple Motor with Steel Pinion for 1/18 TRX4M (INM11-48T), this motor has great torque and rpm!
https://www.injora.com/products/inj...-motor-with-steel-pinion-for-1-18-trx4m-inm11
Gear set, transmission, low range (crawl) (40.3:1 reduction ratio)/ pinion gear, 11-tooth #9776R
https://traxxas.com/products/parts/9776R
TREAL Heavy Duty Steel Center Slider Driveshaft Set (2P) for 1/18 TRX4M, very nice quality, fit and finish!
X003LAVSN5
https://trealhobby.com/products/tre...enter-slider-driveshaft-set-2p-for-1-18-trx4m
TREAL Brass Axle Diff Covers (2P) CNC Machined Heavy Weight 15.8g/pc Upgrades for 1/18 TRX4M
X003K9N9FH (used in FRONT Axle only as it's heavier than the Injora)
https://trealhobby.com/products/tre...machined-heavy-weight-upgrades-for-1-18-trx4m
INJORA 11g/pcs Black Brass Front Rear Axle Diff Covers For 1/18 TRX4M (2) (4M-01BK) (Used in REAR axle only as it's lighter weight than Treal)
https://www.injora.com/products/inj...-axle-diff-covers-for-1-18-trx4m-2-trx4m-01bk
INJORA Overdrive Underdrive Alloy Steel Helical Gears for 1/18 TRX4M (Overdrive front, stock ratio rear)
Will update rest of the specs later, this thing is a looker, super portable and crawls great!
https://www.injora.com/products/injora-overdrive-underdrive-alloy-steel-helical-gears-for-1-18-trx4m
Wheel hubs, 7mm hex (steel) (4)/ axle pins (8) #9750A
https://traxxas.com/products/parts/9750A
Started with Traxxas Wheels, 1.0", Method Race Wheels® 105 Beadlock (black, beadlock) painted gold with some Tamiya paint, but stock tires are not as sticky as they ought to be and these wheels were kinda light weight (brass rings were too much rotational weight) so I replaced the wheels and tires with Injora stamped steel whitespokes.
https://traxxas.com/products/parts/9781
INJORA 1.0" Negative Offset 3.78mm Deep Dish Stamped Steel Wheel Rims for 1/24 RC Crawlers (4) (W1004) just the right bit of offset, looks great so I bought couple sets to play with!
https://www.injora.com/products/4pc...ped-steel-beadlock-wheel-rims-for-axial-scx24
INJORA 1.0" 58*20mm All Terrain Crawl Master Tires for 1/24 RC Crawlers (4) (T1008) The TIRES I'm currently using, perfect balance of height and LCG!
https://www.injora.com/products/4pc...de-for-1-24-rc-crawler?variant=40213035188272
INJORA 1.0" 56*22mm S5 Soft Rubber Rock Terrain Tires for 1/24 RC Crawlers (4) (T1005) Bought these TIRES to play with since I love TSL Super Swampers, but may not run these.
https://www.injora.com/products/inj...el-tires-56-22mm-rock-terrain-for-axial-scx24
Stuffed the tires with some LGRP (Little Guy Racing Parts) foams
1.0" TIRE FOAM REPLACEMENT
https://littleguyracingparts.com/co...-tire-foam-replacement?variant=44823870800184
Couldn't find any good quality plastic replacement bumpers, so I trimmed mine up for more approach and departure angles, reinforced the front with ShoeGoo on the inside after trimming it. E6000 tacked the stock fender flares and running boards to the body as they sometimes popped out of place on hard rollovers. Trimmed them up for little more tire clearance during flex. Removed the faux spare tire and rear mount, made a rectangular black kydex plate to replace it that is captured by the four tiny spare tire carrier screws.
As she currently sits:
Pitchers won't upload atm for whatever reason...hmmmmm....
X003LAVSN5
