Natedog's Honcho kit build now with mo Bacon
As my truck sits now! Red outside paint, drywall tape, lexan scraps and SHoeGoo fixed all the cracks.
Sun's getting low...great day of crawling!
These CI foams sidehill very nicely, a big improvement over the stock Ripsaw foams that would roll under almost until the rim hit the rocks in this same spot.
Bought my kit awhile ago and been taken too long to get her up and crawling. Need to crawl soon! :lmao:
I'm building for scalish crawler with good function, durability and still looking good.
Build specs:
UPDATE: Crawler Innovations (CI) Double Deuce Foams (soft front, medium rear), have another set of mediums, a set of firms, and a prototype pair of Deuce's Wild single stage waterproof foams for testing.
http://www.crawlerinnovations.com/
UPDATE: Now I know why people are so non-excited about the same old Axial plastic beadlocks, metal beadlocks just looks soooo good! Bought new wheels to go with new Ripsaw tires and sweet Crawler Innovations foams, Hot Racing (HR) 1.9 Black Steel H Wheel Hex Drive, scuff sanded, sprayed with dark grey Krylon paint and baked in toaster oven at 200F for one hour to give them a nice look and make the paint really durable! Ended up drilling out all the mounting hex bolt holes and upgrading to RC4WD 2.5mm hardware kit because the stock 2mm hardware stripped a couple screws and didn't look as good. http://www.hot-racing.com/index.cgi?partnumber=BLW19HS01;c=456
45T Integy brushed motor with 20/87 gearing to start, Losi steel pinion gear (runs smooth and last forever, left over from racing) may go with 65T brushed (new and just broken in leftover from another build). The 45T has been run alot and is kinda tired...might cut the com and throw new brushes in it or...may need to buy larger pinion and/or smaller spur gear if I go with 65T motor.
UPDATE: 20/87 gearing and 45 turn Integy lathe motor has been working great with low crawling speed/torque and good top end speed on 3S lipo! Traxxas 21 turn Titan (550 motor) going in next! I need more speed and still retain crawling ability, this will pair with 13/56 32 pitch gears.
East End Machining motor plate, nice thick sweet motor plate that shouldn't flex like the stockers do:
http://www.eastendmachining.com/hedumoplfora.html
Trimmed down some longer screws to make use of the thicker EEM motor plate's longer threaded holes.
Replaced all self-tapping screws in the kit with high quality black oxide coated machine screws.
Stock plastic sliders and no bumper for now, started fab on some sweet brakeline tubing sliders with help from a friend. I had never silver soldered before, pretty easy once you see how...most of the time is in the tubing cutting, bending, notching and sanding.
UPDATE: Narrowed stock plastic sliders, they are cheap, work great and flex when it goes tumbling 20 feet down the rocks which helps prevent breakage.
Tekin FXR
Turnigy 3s 1300mah LiPos with forward battery tray
Four link rear
4 link front (including panhard) and frame mounted servo, found that axle mounted servo gets more steering travel with less fuss and is easier with less parts to get wacked by rocks, so that's what I went with in the end.
Modded stock shocks without bumpstops. Rebuilt my stock Axial shocks using Traxxas #7062 shock rebuild kit o-rings in place of the Axial black plastic spacer (between the two existing red o-rings), filled with fresh oil and crawled all afternoon, no more leaks!
UPDATE: The Traxxas o-ring mod leaked too, but the added stiction of the tighter o-rings still act like they have oil in them. After lots of shock leaking, repairing and reading, I'm upgrading to Pro-Line Power Stroke Scaler Shocks (90mm-95mm) 6060-00 http://prolineracing.com/performance-parts/power-stroke-scaler-shocks-90mm-95mm/
Stock driveshafts with rings for now, need to upgrade but don't like the weight of MIPs.
Aluminum C Hub Carrier - Black p/n AX30495
http://www.axialracing.com/products/ax30495
Axial Hi-clearance Knuckles p/n AX30533
No link on Axial's website...discontinued??? I hope not!
Axial CVDs in front axle p/n AX30464
http://www.axialracing.com/products/ax30464
Blue Monkey RC titanium High Steer Kit with Axial aluminum C-Hubs and High Steer Knuckles.
http://www.bluemonkeyrc.com/catalog/
New servo UPDATE: Hi-Tec HS7955TG steering servo http://hitecrcd.com/products/servos...h-torque-titanium-gear-coreless-servo/product
CC BEC http://www.castlecreations.com/products/ccbec.html
Spectrum DX3C
DX3C DSM 3-Channel Surface Radio (SPM3300): Spektrum - The Leader in Spread Spectrum Technology
Body mounted at the rear (hinged) and then a single body mount post up front. Need some ideas how to hinge the rear, all mine have not worked out well. Was going to bend up a piece of aluminum, screwed to the bottom of the rollcage with four 3mm screws (2 of them the forward spare tire mount screws and then 2 near the rear of the cage). It would pivot on the two rear crossmember screws which would be longer machine screws with locknuts. Kinda complicated and I didn't want to drill holes in the cage. Next was two nylon wire loom clamps around the cage and then screwed to the rear crosssmember...simple, strong and light. The 1/4" diameter are too small and next size up (3/8") is a lot too big. Hmmm...maybe shim it?
Black Nylon Cable Clamps - Bag of 10
Cable Clamps for Securing Electrical Wiring | WiringProducts.com
Pics coming...I have no good fireworks to light... :roll:
EDIT: Pics are up....more coming.
Test fitting stuff. Paint is Tamiya PS-48 Semi-Gloss Silver Aluminum Polycarbonate spray paint, this stuff looks great just like the name says and goes on nice, thin just like an airbrush. I've never used it before being a Pactra fan and the Tamiya was $14.50 per can!!! wtf? Well it did the bed great, but the cab was kinda thin, uneven, and patchy. Backed it with Pactra Sprint White and then black, well it didn't come out quite like I wanted after like eight coats and it was too late after backing it with white so now it looks a lot like oxidized silver paint...so still scale...lol. I like it, but next time will use twice as many coats before backing it with any other color!
Servo mount plate mockup (lines scribed and holes marked...nothing drilled or cut yet):
Servo mounted:
Start of panhard bar frame mount:
Build specs:
Tekin FXR
Four link rear
Spectrum DX3C
Servo mounted:
