Great review thanks .. the positives high speed cornering and ground clearance improved? Negatives impacts concentrate the landing force threw the shocks the cage is impacted and it's positioning is more likely to be damaged.
Have you had a chance to race it with the adjuster mounted? I'd be real interested in hearing about that experience and your opinion?
I see those bending way easier than the shock adjuster.i seen a video on youtube of some dude using the shock keys for the scx10 on his front tower.
Thanks for that, sounds promising [emoji2]There is something that you can do that will make the shock adjuster actually do what it is intended to do. If you look at the bottom of the chassis where the lower control arms mount to the truck body, you will see that the chassis actually stops the arms from dropping any lower than the current position. Take the arms off and use a file or Dremel tool etc to remove a little material where the arms come into contact with the chassis. This will allow the arms to droop or hand lower when you run the adjuster. The shocks will no longer be limited in travel either. I have done this mod as have a number of others and it works awesome!![]()
I gave it a try and must say that high speed handling is improved vith shock adjuster. It is definitely good for going fast and maybe for racing. If you bash hard and do lot of high jumping, then longer suspension travel without adjuster would be better IMO.I do not like mine either. It makes front way higher and shock travel distance is very limited. I did not drove it yet and Im thinking I even do not try it as Im dissapointed with how it feels.
Once they arrive I will mout new PROLINE Power Stroke Shocks (6063-01) back on tower and put 45wt oil into them - that should be much better.
