My losi micro crawler samurai scaler has been my project for the past month
and i think it really works and looks realistic (even has a little tighter front end (still has all the flex) from the steering mod i did..
so i started with the stock micro crawler instantly took out the springs and made some lights using two nice leds i had
i ordered a 1/24 scale Suzuki Jimny model off ebay and got to work!
I made it into a truggy at first.
ittle cooler fire extinguisher and tow strap in the back
cards tape glue and paint
winch/bumper solder, plastic, wire
The truggy was cool and all but I got a real samurai and I and thats kinda what i wanted to
lean more towards on this build
later I cut the back part of the bed off to extend extend it to match the length.
sliders from some square tube like steel little bar
I wanna get a key string pully thing like someone said for the winch but dey hard ta find?!
i drilled some washers to weight the tires and got the lipo in there
heres on the mountain
ordered some boggers from rc4wd! i put the stock tire foams in them and their soft but nice and chunky still. o yea i cut the springs and put them back on too
i just gotta do something about the wheels rubbing on the uper front links.:ror:
just got in metal gear servo! stock one sucks, sorry to say it losi
i cut the other 3 arms off the horn and mounted the servo a little higher with only two screws in the middle holes. looks good seems to work fine
then made a new tie rod that looks real (metal/and stabalizer)
wasn't to happy with the boggers rubbing on my top links (no spacers) with the thing set to minimum turn dot.
so i built little spacers for the top shock mount and bent the links in! nice turning again
no spacers!
no spacers!
