My new shock mounts.
Looks nice. Are you experiencing any slippage in the links(pivoting) seeing that they are just supported on either end and angled with 1 contact screw point?
thanks
No, I have not had any slippage, If you want you can use the top hole on the mount and then the bottom hole will line up with the corner of the chassis plates and you can put a bolt through there, then there would be no way they would move. I did this at first but wanted to run them the way I have them now to see if they would slip...so far so good.
