WesTX
Building a do it all mega truck. Goal is a do it all truck, and will also be a tow rig for my 38" Mono-Hull Outboard powered RC Boat. Want to be able to crawl a bit with it, do TTC style stuff, as well as be a mud/basher truck. I will spend lots of time and research to get the suspension right, to make sure it performs. Here is the proposed parts list. Still waiting to get some parts, those are marked with an asterix below.
Chassis and Body:
- Chassis built using Harley Designs Mega Mud Truck Chassis plans. Will be some slight mods to fit body/suspension but mostly based on the plans. To be built from 0.250" OD, 0.049" wall 4130 tube. Chassis side plates will be 1/8" steel, skidplate will be 1/8" steel.
Have the chassis material, should start building this week.
- Body will be (2) Tamiya F-350 body's chopped up to make a supercab body. Will also extend the hood and open up the wheel openings for the tire size. Bed will be hacked up and the bedsides used to skin the chassis in true mega-truck form.
Have the parts for the body, should start hacking it up and building the body in the next few weeks.
Drivetrain/Electronics:
- Traxxas Summit 2 speed transmission mounted via Jasons SCX plate.
- Kershaw Designs twin 700HO motor setup
- Traxxas EVX-2 ESC *
- Kyosho Mad Force Axles (bought from the ebay with a used mad force), still need some SuperShafty upgrades.
- Drivelines built using a blend of parts and pieces *
- Undecided on servo yet *
Wheels and Tires:
- RC4WD 2.2 Mud Bashers
- Undecided on wheels, possibly DCW 2.6" wheels. Biggest thing is hex's for the axles. *
Suspension:
- 4 link front and rear using Ti Links and Revo Rod Ends *
- Losi LST Shocks on all 4 corners - http://www.horizonhobby.com/assembled-shock-w-spring:-lst--aft-losb2878 * From what i understand - 1.4" Diameter and 6" long. Should provide plenty of dampening!
- UC Fab Yeti XL sway bar in rear - possibly front as well depending on if it needs it. Chassis will have mounts for front sway bar integrated in case it is needed. *
Will no doubt have more details to add later. Will add as I get there. Just wanted to start this to start jotting down my ideas.
Wes
Chassis and Body:
Wheels and Tires:
Suspension:
Wes
