I've been tinkering on and off for the past several years with ground based FPV. There's a challenge that comes with trying to create a good, stable, usable video signal from an antenna a few inches off the ground. It's been a fun way to combine two of my favorite hobbies - ham radio and R/C.
I've built a Summit that's been through more incarnations than I can remember, and earlier this spring I used an Axial SCX10 chassis as the basis of a smaller, indoor rover. All my builds so far have been of the 'rover' variety - more of a platform to test technologies rather than something trying to re-create a full-scale driving experience. Lately I've been getting the itch to change that...
I've got a setup on my Summit rover that I'm happy with (for the moment) so I didn't want to go the Tonka Summit route (yet). I saw a few FPV SCX10 scalers, but everything looked really cramped. Then I saw this video:
<iframe width="560" height="315" src="https://www.youtube.com/embed/9fMK7vN2GYE" frameborder="0" allowfullscreen></iframe>
That setup looked perfect to me! I really liked the look of the Wraith interior, and it's a capable enough vehicle to be driven just about anywhere. I spent a few more days watching FPV Wraith videos on YouTube. My mind was made up - I was going to build a Wraith FPV scaler. Having built a few ground based FPV rigs I've learned a few things that influenced me heavily in this build:
- Anything above a brisk walking speed when driving FPV feels like warp-speed, so this Wraith was never going to have to go fast or need a huge brushless power system.
- FPV gear and water don't mix! A failed FPV boat project taught me this. This Wraith is going to be sunny day, dry-weather rig only. No waterproofing necessary.
- Your perspective is a LOT more limited inside a vehicle than outside of it. That's why 1:1 off-roading involves a lot of spotters outside the trucks. Since I won't always be within eyesight and don't like the walk-of-shame to flip over a rolled truck, this Wraith won't be doing much serious rock crawling.
- Since I'm not going fast and I'm not doing any serious rock crawling and I'm not getting anything wet, I don't need a real fancy, quick, high torque, waterproof steering servo.
- Since I'm not going fast and I need a lot of nice low-end control I can use a cheap, sealed can brushed motor instead of an expensive brushless motor.
- Money saved on the motor and steering servo will go towards a Holmes BRXL ESC. There is no smoother brushed motor ESC on the market - PERIOD. Having nice smooth low-end control is critical in an FPV vehicle - you don't want the truck glitching or jerking from a dead stop and jerking the video around. No matter what anyone says, you CAN'T use this ESC in ANYTHING without a BEC! The internal BEC is weak and it will fry out over time. Plan on spending another few bucks and getting a Castle 10amp BEC to go along.
- Separate your antennas as much as possible! I was going to keep my R/C receiver antennas up front under the hood and keep the video transmitter antenna as far back as possible.
- The RC and the video equipment should ALWAYS run off separate batteries! Otherwise you're going to be constantly fighting noise and interference in the video link...
I started searching eBay for new or used Wraith rollers. Patience paid off when I came across a used roller with a few key upgrades. It's always a bit of a risk buying a used rig on eBay, but the pictures looked pretty good. The seller was quick to ship and when I got the rig it was in great condition!
It came with some nice hop ups:
- Axial aluminum c's
- Axial aluminum knuckles
- Axial aluminum rear axle lockout
- Aluminum steering lower link
- Aluminum upper links
- Level 3 droop kit
- Battery up front mod
- Axial aluminum shocks, red stripe springs
- 20t HPI motor
- 80t spur/18t pinion
- Fastback body
- Axial BFG Krawlers on Axial Trail Ready beadlocks
I stripped it down as soon as it came and went through the transmission and the axles. Everything was nice and tight and looked brand new. As much as I liked the look of the fastback body mod on the Wraith I wanted the stock roof and rollcage in place to protect the rear of the Wraith with the video transmitter and antenna in case of a roll-over. I found an eBay chop shop rollcage and ordered a clear lexan body kit from Tower Hobbies. I threw in a few cans of Tamiya Camel Yellow and Tamiya White, then Black to back it. I love Camel Yellow...
I reassembled everything, dropping the HPI 20 turn motor for an RC4WD 45 turn motor and replacing the 80/18 spur/pinion combo with an 87/10 combo. I hot glued the Holmes BRXL ESC and the Castle BEC to the frame piece the receiver box usually connects to (AX80081) and connected up the 45t motor. I installed a Turnigy TGY-5521MDHV and a 25t metal horn for steering duties. My eBay Wraith came with an aluminum lower steering link (the longer one) but was missing the upper one. Some 8/32" all thread and Traxxas rod ends provided a temporary fix until I can get something a little more pleasing to the eye. I also flipped the shock/link mounts on the axle to lower the COG a bit.
The electronics stuffed under the hood
I ditched the wheels and tires it came with and ordered up a set of Pro-Line TSL XL Swampers mounted onto an old set of Hot Racing aluminum beadlocks. The TSL XL tires are AWESOME! They're huge, sticky and they look just plain -mean-. The foams they come with GARBAGE. The ones I got weren't even round! I had to wet them down and heat them in the microwave to get them to expand back to a round-ish shape. After doing some reading on Wraith builds I ordered a set of Crawler Innovation Single Stage foams and a set of Double Deuce comp cut foams. I'm not sure if it's going to be smoother to have soft foams or harder ones which transfer all the load to the suspension. I've installed the single stage foams and they are light years better than the Proline stockers.
Pro-Line TSL XLs
My eBay Wraith came with aluminum Axial shocks. I thought for sure that would be an upgrade from the garbage plastic shocks I was used to. Nope - these ones leak just as bad. The oil that managed to stay in the bodies was 40wt and made the suspension way too slow for the smooth ride I needed, and the stock Axial red stripe springs were WAY too stiff and bounced all over the place. I replaced them with Traxxas Big Bores (TRA2662) filled with 20wt oil and I'm using a set of Losi white springs all around (LOSA5147). I had to cut the lower front bumper cross-member off with the new shocks on as it dropped the ride height even more. Compared to the Axial shocks I've got a lower ride height and more suspension travel - I'm very happy!
The cut crossmember and Turnigy steering servo
I used a Dinky R/C rear tub to house the video transmitter, video switch and LiPo to power the video equipment. The video transmitter is a Cricket 600mW 5.8GHz unit from Ready Made RC. I'm using a set of FatShark spiroNet circular polarized antennas on the video transmitter and receiver. I removed the driver's side seat and put a Ready Made RC Mobius pan/tilt kit in its place. I'm using a Mobius wide angle lens camera for my main camera and a Ready Made RC Pico Wide camera for my rear backup camera. A three-way video switch from GetFPV.com allows me to switch between cameras from the transmitter.
The Dinky R/C bed tub housing all the video electronics
The Mobius camera ended up really stuffed into the cab. The lens almost touched the steering wheel and its size limited how far it could pan & tilt. You can see in the picture below what I'm talking about.
The Mobius camera stuffed up against the steering wheel
The layout of electronics on the cage, you can see how little room the camera has to move around
I ordered an 8" extension cable for the camera lens off of Amazon. This allows you to take the lens out of the camera housing. I put the camera housing into the Dinky R/C tub and was able to shave down the pan/tilt mounting plate quite a bit before attaching just the camera lens to it. The difference was just what I wanted! The lens is now in the same place a driver's head would be and the view looks perfect from the video feed!
The lens outside of the housing sitting on the shaved down pan/tilt mount
The Mobius case now sits in the Dinky RC tub with the rest of the video electronics
I cut up an old piece of lexan to use a cover for the Dinky R/C bed. The hood is held on with high strength velcro. I run a 4s 1500mah battery under the hood to power the car and servos and a 1000mah 2s battery sits in the rear bed to run the video gear. I'm using a FrSky Taranis transmitter for control paired with a FrSky long range L9R receiver. The L9R comes with two external antenna which a glued to crossmembers under the hood. There's a set of aluminum lower links sitting on my bench waiting to go on. I'll post up some video as soon as I can get her out for a good test drive. For now, some picture will have to do!
Profile shot
Peek-a-Boo
Can't show off a build without flex shots, right?
My FrSky Taranis transmitter
