My AX24 kangaroo build
benoj
Madrid, IA
Recently finished my ax24 build based off the injora kangaroo carbon fiber chassis. Had plenty of injora parts besides the chassis suck as: adjustable servo mounts, c10 high clearance links, steering links, driveshafts, 50?mm shocks, and scx24 skid plate. For brass parts I went with hobby park diff cover and knuckles up front plus wideners all 4 corners. From AliExpress I got 11% under drive in the rear and 13% overdrive in the front for like $2/each. Went with injora bead locks with ogrc comp pin tires. For electronics I’m running a fly sky g7p with a decased 4ch rx placed next to transmission and all clears with no rubbing. Servos I’m running are dash rc 9kg micro servos off amazon. Esc is an am32 unit from AliExpress along with a 4000kv micro outrunner that can mount to stock plate (total cost of about $30), but mine is attached to a injora red mounting plate from the brushed 050 motor I was running. Runs incredibly smooth and the 2a bec is working great with these servos.
Plus a short vid of the slow speed crawl
