Another option if you want to save a few bucks is to run that esc with a Holmes hobbies revolver. They are loud little motors but out perform any other brushless motor as far as crawling goes. I'm just not to sure if the SCT sidewinder has the same software as the SW4 (sidewinder 4), so it might not be as smooth as the SW4, but it probably wouldn't be noticeable to a newbie.
Sent from my SM-G970U using Tapatalk
Castle Creations 1/10 SCT Sidewinder WP ESC + 1410 3800kv Sensored Motor COMBO
Can this setup be used for trailing or is it too much Kv ?
Any help will be great, thanks.
I was able to swap that motor and esc out for this, Castle Creations Mamba Micro X Crawler Esc w/ 1406-2280kv Sensored Motor Combo.
Let me know if this will work a bit better, thank you guys for all of your help, being new at this I have a ton of questions. Thanks for all the help
That should be better suited for a crawler.
Thanks again guys, with everyone’s help I learn a little more each time.
Best bet is a HobbyWing 1080 ESC plus Holmes Hobbies Trailmaster Sport 550 21t - totaling under $65...
It's a programmable ESC, and the motor has more than enough oomph to push the somewhat heavy Bomber around.
Keep stock gearing, 3S is no problem!
(Bombers really need that 550-sized can for the low-end torque increase over a standard 540 motor)
I installed the new mamba micro combo and it seemed to work until I turned it on and it was running in reverse. I was able to switch this through the Traxxas app but I noticed it has more rpm running in reverse than forward and I wasn’t able to figure it out. The aux function dosent seem to work either but who knows it might even be a compatibility problem with Traxxas, any help is welcome
