MNRCRC 2016 Rules Discussion Thread
I think as far as 1.9 th e only rules should be is frame rails and 1.9 scale tires, anything else is good to go.
In 2.2 trail no comp chassis, and only scale tires, but wraiths and bouncers are good to go. Does not have to have frame rails.
In pro same rules as always, but and other comp.chassis trucks run here.
The only other rule I think should be implemented is you cant run the same truck in 2 classes, just by changing tires. I think it should be a different truck in each class.
Other rule only.for pro class is if your truck breaks and you can't repair it you should not be able to run a different truck, the truck you start with is the truck you finish with.
Sent from my SAMSUNG-SM-G870A using Tapatalk
I'm just fawking with you guys.
I'm good with the basics.
Scale tire
No tvp
6s lipo
1 brass pole
A whole season shouldn't not be ran with something like this but if a new person wants to run a couple events I say go for it. Fawkers are not gonna take my participation trophy away.
