minor_threat
I had a problem with the fxr last night and today. when reversing it wouldn't stop when i let off the trigger. I checked my TX as per the tekin thread but that was okay. I have my drag set to full and this issue was only happening in reverse; flat and incline, so i am wondering if at certain times, my battery cable might have been pushing on the switch as it's located right at the front and so i moved that to the side of the chassis. i won't know if it works until Friday but maybe that did it. we'll see.
I also moved the antenna wire off the motor wires as I started thinking that there might be some sort of feed back coming from them...probably not as I'm using a spektrum 2.0 but still, worth the relocating if all is well. I wonder if the upgrade to the software might be an issue, not much feed back on that beta that was downloaded that I'm aware of.
