minor_threat
Thought I'd post the tvp bodiless chassis build as my first build thread so here it goes.
After not liking some of the other bodiless chassis out on the market I called my friend with a cnc and sent over some drawings and went from there.
Once I got the chassis back, I tore down the DMG chassis and found some time to get panels and make a new skid for this Ground Haug chassis.
I made the skid so I could get a narrower lower angle and not hit the motor like on the str ones. I kept the width of the tranny plate stock at 3+".
After getting the tranny bolted up on the beta version of this chassis I tuned the shocks which were at that time the stock axial shocks drooped with the dampers on the outside.
I like how I put the holes for the uppers, closer to the insides of the chassis but in doing that I had to get some 65mm uppers and I also used a 6x6 spacer on the rear upper where it mounts to the axle since I don't want to go with a 4-way.
I did play around with the lowers and tried using Revo fronts and 106mm rears on the lowers. works fine. I had a ground clearance of 2.5" which was okay, the axial droop was adding to that when needed which was great. I adjusted the shock position a couple times as I designed this chassis to allow for a non-contact area with the shocks and the chassis. You could get sick amounts of articulation if you wanted too but I'm happy with 45*. I also had lower shocks as this was designed for 4" and so I placed the shocks closer inboard - a lower angle in relation to the lower rods.
all in all, i liked the response I was getting on both large boulders and small indoor course rocks, I was climbing at 64* up gunnars angle board with not front tire lift at all. at this time I had stock tires and rims, fronts weighed 8oz and the rears were 4oz. stock steering etc.
I sent over changes to the shape, took out holes and a swoosh and have my final chassis that I drove for the first time today at the HobbyTown Concord - CVRC comp and placed 3rd...only because I forgot to NOT pick up the rig...ugh...twice i did that...but still, 3rd is great for a first run.
I had to tear down the beta, make a new delrin base plate - still stock width and get the traxxas pede rears cut, drilled and mounted the cap to the axial shock ends, ad oil -100 wt and did tlc medium internal droop. have ricky at HT solder the motor for me, he's a pro IMO, then drive back, get this thing ready...ugh...the night before the comp I was finally laying mask down to paint the logo and flames, finish my last mayhem beadloc with proline 5.5" double foams and get some sleep.
I used 98's up front and 106's on the rear for the lowers. 65's on both F>R uppers, a 6x6 on the axle end of the uppers at the rear. my plates bring in the lowers 1" under the tranny. I have 6x6's on the uppers where they meet the chassis. I designed the chassis to set more forward and did the plate to flip the tranny.
after the first run where I wasn't getting any chance at keeping my front end down on the 60* course, i moved the rears inward a few holes and still kept my wb at 12.5 as per the judge and giving me a lower ride height of 2.5 instead of the 3" i had at the start. after that I took the next two courses with flyin' colors.
for mounting the shock towers I used 7x55mm and 7x10s. you could change with of course and not effect anything. the shocks will never touch the chassis.
I have tekin fxr and a 55t hand wound motor, 2.0 spektrum and run nihm saddles on the front. a cheap hitec 645 servo and rovers on mayhem's. for the panels i used 1/8" lexan on left over flm rods but that will change as i'm making my own style of rods and all the screws, plate and rod come as a kit thnx to racersedgemachine.com
I was going to work with ted from dark soul on this as his laser is faster and cheaper then cnc but after sending him the drawings we both got busy. the guys from rem did a great job at banging this out in a day. I think they're gearing up to sell these.
here are pics:
I don't have any pics of the comp as the guy taking pictures didn't get everyone's rig. I'm not selling this as it's still in the patent process and I don't have gold star but someday shortly...so don't ask.
i do have a standard tvp of this chassis too so I can run my lexan bodies but this version is my fav.
parts list:
custom tvp bodiless chassis
tekin fxr esc and 55t moto
2.0 spektrum rx/tx
hitec 635 servo
8 cell nimh saddle pack
6x65 uppers with 6x6 spaces at chassis
6x6 spacer at rear axle
6x106 lowers at rear
Stock lowers at front
m3x35 screws for tranny plate
m3x15 screws for shock mounts
m3x10 screw for upper rods to chassis
m3x5 screws for body panels
Mayhem machine finish 7's with grinders.
17 - .24oz leads in front - nothing in rear (they're stock at 4.25oz)
HT Rovers
Pro-line 5.5" double foams
Traxxas pede/rusty/maxx shocks with axial ends on caps, 100 wt oil and drooped.
12.5WB, 2.5-3.0 belly clearance, front atriculation 5.25", rear 6.25" at current shock settings.
There you go. my build thread. not much left to do except change the steering rods since I got one now (thnx HT) and get my mayhem's shinier then Mikes/cvrc.
6x98 lowers at front
here are pics:
parts list:
2.0 spektrum rx/tx
hitec 635 servo
HT Rovers
