I made some modifications to my crawler today, which I'm testing out. Other than having put the
ESC on the front servo and added a LiPo battery, this is what I came up with:
1) Losi Mini-T ball ends and threaded rods replaced the upper and lower links. This lengthened and lowered the truck.
2) Cut the drive shafts, put each end in a section of aluminum tube with a little CA and added a section of black heat shrink to
cover.
3) Cut small sections of nitro fuel tubeing and slid them onto the output yolks to keep them from snapping off.
4) Drilled out the chassis holes made for the ESC/battery mounting platforms and used them for the upper shock mounts.
5) After removing the tires from the wheels, I cut the foam down to about half and installed lead weights around the inside of the wheels.
6) Installed red Micro-T shock springs (stretched to stock length).
Now it is longer, the wheels are weighted and the foams allow the tires to compress more. It seems better and the COG is
definitely lower, but it does bottom out more often. Still tweaking...
The pictures also show a comparison with a stock micro crawler:
