Maxx Crawlers Gallery
NIce Maxx's Here Mine
Maxxx Crawler!!!
Here are the spec's from my crawler...my first build I've ever attempted. There was a lot of trial and error and frustation. I made all the links, the chassis, the battery tray, the servo mounts and everything else from scratch by hand. All made with Dremel, drill, grinder and brain. After a lot of reading, looking at these pictures, and trying stuff that didn't work, I now have an awesome truck!! Thanks to all of you out there. See ya on the rocks!!"thumbsup"
The shots are from my favorite playground, the Susquehanna River!!
Truck Base : E-Maxx
ESC: Traxxas EVX
Motor(s): Hand tuned twin 27 turn epics and 9t Robinson pinions
Servo(s): Tower pro 995mg w/aluminum arms
Trans: E-Maxx locked in 1st gear w/72 t spur
Axles: T-Maxx wide A's locked out
Tires: 40 series Moabs w/Pro-line Commando beadlocks and star cut foams
WB: 14"
Overall Width: 18''
Diff clearance: 3''
Center Chassis clearance: 6''
Overall height: 13''
Overall weight: 10 lbs.
Truck Base :T-maxx/ custom chassis 4 link
ESC:Traxxas XL5
Motor(s):75t Lathe
Servo(s):tower pro 995 front &rear
Trans:pede locked
Axles: -maxx locked
Tires: Losi Rock Claws on Maximizer beadlocks
WB:16.5"
Overall Width:16.5"
Diff clearance:3.75"
Center Chassis clearance:5.75"
Overall height:10.5"
Overall weight:12 lbs.
Comp Maxx
Heres my comp crawler,
Specs,
Custom Maxx axles locked,
Lengthened Revo driveshafts,
Axial AX-10 trans,
Johnson 550 motor on a GD-600,
Moped esc,
Traxxas TQ3 with rear steer mod,
Tower Pro 945mg servos front/rear,
MudSlingers 40 Series,
RC4WD 40 Series beadlocks,
Droop with Maxx aluminum shocks front modified rear,
Duratrax Mini Quake springs for internal springs
It is currently going through a rebuild so most of the above specs will not aply afterward. Onto the pics,
ThanX,
Krystopher
maxx trans
axles are all lower arms.
stock motors with 2.5/1 gd600's 72/18
heavy
moabs on narrowed BL's
blah blah
PM me if you have any Q's.
Here's a few pics of my maxx crawler, as of now I'm running full droop susp. with mini-t springs and 50 wt. oil inside maxx shocks,can't wait for spring to get out and test it!!!!!
Truck Base :emaxx
ESC: Novak rooster crawler
Motor(s):integy v-10 55t
Servo(s): hi-tec 645 X 2
Trans:emaxx locked into 1st gear 9t pinion 72t spur
Axles:maxx locked out susp.
Tires:40 series moab on proline beadlocks
WB: 17 1/2"
Overall Width: 17 1/2"
Diff clearance: 3"
Center Chassis clearance: 4 1/4"
Overall height: 9 1/2"
Overall weight: n/a
no action pictures as of yet, the snow has all the rocks covered
Here's my first build outside of an AX10. Base Chassis, axles, Tires bought from Derwood21. Just had to make all steering linkage, trans mounts, and side plates (roof, rear, and hood were included)
Full 4 wheel steering and 2 speed is operational
Base: Emaxx
ESC: Novak Rooster Crawler (new version)
Motor: Integy 60T
Servos: JR z9100t front, HS-5645MG Rear, Eflite 7.5g sub-micro for shifter
Trans: Emaxx with RC4WD Aluminum gears and full functioning 2sp
Axles: Locked Emaxx
Tires: Losi Claws
WB: 17 1/4"
Width: 16 1/4"
Diff Clear: 3"
Center Clear: 4"
Total Height: 9 1/2"
Weight: Unknown as I don't have a scale currently
PICS ARE Roughly START TO FINISH
Rock Demon
Truck Base :e maxx
ESC:mtroniks
Motor(s):p2k
Servo(s):hs645
Trans:e maxx
Axles:custom steel solid axle
mip cvds
Tires:moabs
WB:18.5 inches
Overall Width:18 inches
Diff clearance:3.25 inches
Center Chassis clearance:3.75 inches
Overall height:10 inches
Overall weight:15 pounds
Red Devil
Truck Base :maxx
ESC:sidewinder
Motor(s):p2k
Servo(s):hs645
Trans:stealth
Axles:custom solid steel maxx diffs
cvds
Tires:2.2 moabs or 2.2 rock claws
WB:12.5
Overall Width:front 12.25
rear 11.5
Diff clearance:2.25
Center Chassis clearance:2.75
Overall height:7.5
Overall weight:7 pounds
Stick Maxx
This is my first attemt at any thing in the R/C world. Some of parts I am little embarassed about :oops:. The chassis and the axle housings are made out of alluminum from the local hardware store. The body is off of the Emaxx I hack. I am looking for a replacement body, but that will be awhile before that happens.
Truck Base : Used Emaxx parts and alluminun
ESC: stock novak
Motor(s): Integy 55t
Servo(s): Hitec hs5955tg / Hitec hs-645mg
Trans: RC4WD V2
Axles: Custom Emaxx
Tires: Moab XL
WB: 18"
Overall Width: 16 1/2
Diff clearance: 3 1/14"
Center Chassis clearance: 5"
Overall height: 10 3/4"
Does any one know of any wheel wideners for an emaxx to 23MM? These wheels are to far in to clear my batteries.
here my emaxx crawler
integy 55t single
gd600 rear reduction
steel cvd
locker front and rear
locker in 1st gear
tazer 15t esc
narrowed rims
IF YOU GUYS SEE ANYTHING THAT I COULD TO TO MAKE THIS TRUCK BETTER PLEASE LET ME KNOW!!!!!!!!!!
Truck Base :emaxx
ESC:tekin rebel 2
Motor(s):55t 66/9 gearing
Servo(s):dual hs-645's(need some fat 805bb's)
Trans:stampede
Axles:maxx with narrow bottoms for the top
Tires:aluminum maximizers with lsts
WB:18 3/4
Overall Width:18(want to make in narrower)
Diff clearance:3
Center Chassis clearance:4
Overall height:8 3/4
Overall weight:9 1/2 lbs
Brushless emaxx
Truck Base : E-MAXX 16.8
ESC: NOVAK BRUSHLESS
Motor(s):BRUSHLESS
Servo(s):JR Z9100HVT
Trans: STOCK 2 SPEED
Axles: STOCK WITH ALUMUNUM
Tires: MOAB 40'S
WB: 16.5
Overall Width: 16
Diff clearance: 3.5
Center Chassis clearance: 5.5
Overall height: DONT KNOW
Overall weight: DONT KNOW
scaled.php
scaled.php
my maxx crawler
i have a custom built maxx crawler, the axles are made from metal tube,the tranny is a differential and two spur gears to lower the speed and increase the torque. i have moab xls and i have a pair of swamp dogs this thing is huge
Truck Base : e maxx
ESC:super rooster
Motor(s):55t
Servo(s):5955tg
Trans:custom
Axles:custom
Tires:moab xls and swamp dogs
WB:20iches
Overall Width:17inches
Diff clearance:2 inches
Center Chassis clearance:4 1/2 inches
Overall height:10iches
Overall weight: 13lbs
side view
comparison to my axial 2.2
PYRO's MAXX/ txt contraption
Truck Base : highly modded TXT frame
ESC: SR
Motor(s): peramax 600
Servo(s): hightec 5945
Trans: modded TXT, gd- 600- 89:1 gear ratio
Axles: maxx
Tires: moabs
WB: 17"
Overall Width: 16"
Diff clearance: 3" f/r
Center Chassis clearance: 4"
Overall height: 9 3/8" w/ body
Overall weight: heavy :mrgreen:
Ck-maxx
Heres my unfinished C-MAXX
"thumbsup"
ESC: SR
Axles: maxx
Tires: moabs
WB: 17"
Overall Width: 16"
Truck Base :e-maxx
ESC:tekin rebel 2
Motor(s): integy 55x1
Servo(s):tower pro 995 and hs 5645mg
Trans:emaxx locked in 2nd
Axles:emaxx locked with spools
Tires: moab xl
WB:17"
Overall Width:17"
Diff clearance:3" front 3.25" rear
Center Chassis clearance:4.5"
Overall height:10.75
Overall weight: unknown
