Mamba Monster X help
pkfab1
US
hi everyone. i have a MMX 6s esc W/3brothers Blackjacket 6s motor that was cutting out after 2-3 seconds of wide open throttle....I updated the firmware, reprogrammed it. and now it seems to have no start up power. if you pull the throttle on the radio you can manuallu spin the motor can and it will take off.. im acually confused.. help!!!!!
If motor and esc are brand new, have you contacted the respective manufacturers? If for no other reason than getting the issue registered before messing around and possibly screwing up warranty chances if it comes to that. And because manufacturers should provide support for their product rather than outsourcing it to forums.
Sorry I don't have better info. This sounds like a motor issue to me but that's not much help.
What batteries are you using? If your C-rating is too low you'll choak your power under load and you'll get a stuttering when you are hard on the throttle.
