Time for a little update. I just started pulling the rear axle apart to verify my last breakage and had a bit of a surprise. The ring and pinion are still good and all the bearings spin freely (I'll be replacing them anyway) but the ring gear/carrier screws had all sheared! That would explain the pop that I heard. They're all broken at about the same length, so I don't think anything backed out first (could be wrong) though there is a new "machined" groove inside the 3rd member.
I don't really think this is an area that needs upgrading since my last 2 packs were run in 2wd, on asphalt, pretty much full throttle the whole time, and I wouldn't consider that to be "normal" circumstances. It probably just went from ridiculous wheelspin to full traction in an instant and something had to give. I'll probably still order up the RR gears, but I'll do a little more digging to see if there's room in the case to put a slightly larger/higher grade machine screw in there.
Are there any happy VP axle housing owners out there? Id like to hear from someone thats been running one. I just lost another inner pinion bearing yesterday and im done investing in 5x10 bearings. SSD third member definitely an option im looking at but I really like VP's bearing caps in their other housings and the almost no gear deflection that comes with aluminum housings. Id appreciate any feedback.
Good thinking on the TH diff cup! I'll add that to my list.
So it should work perfect on the from diff. Mine just sheared the screws yesterday.It comes with 2x6mm screws, so I went with protek 12.9 2x8mm flat head. Also another thing to note, if your using it in the rear, the stock locker doesn't fit all the way so it needs dremel work (machining wasn't finished on the slots). But if your using the stock spider gears, they fit fine.
Who here has made the switch to 17mm hubs? I'm just about due for new tires/wheels again and was intrigued by the SC8 beadlocks with 17mm hexes.
