Here is what I did to change the wheelbase.
First I looked at moving the rear axle in because I thought it would be easier.
My issue there is that is moves the COG towards the rear of the truck in relation to the wheelbase. I'm never a fan of doing that.
I also wasn't sure I'd be able to reuse the same body mount holes and I hate punching more holes in a body.
So I decided to look at the front.
Benefit is that you are moving the COG forward in relation to the wheelbase, which would make for optimum climbing ability.... and as you will see, I used the same body mount holes.
"thumbsup"
I started by removing the cross brace from the front shock towers then I loosened the shock towers themselves. I reinstalled the cross brace but flipped it 180*. Then I slid everything back right up against the the servo. This causes the shock towers to move back about 1/4". So, I actually let the servo be my guide on location for the shock towers.
Next I drilled some M2.5 holes through the chassis using the shock towers as my template. For the forward holes, after I punched through the chassis I kept drilling into the servo mount. Then I switched to an 3MM bit and drilled the front again, but only through the chassis, not the servo mount. That way the servo mount will act as the nut for the screw.
For the rearward holes, I tapped them to M3 thread. You could just as easily put an M3 nut back there... I just have a tap so why not.
"thumbsup"
