Live Venom Creeper build today!
Set the cable tight on the servo end and take the slack out at the axle end.
Try to follow the drawings on the instructions and I wont say anything. Lets see if they are clear enough.
Shock Tip: remove the internal spring spacer for more ground clearance.
Once you set the tube as deep as you can in the red alloy cable adjuster it will stay. The cable stay on the link will keep it in place.
SO, what the hell are you guys having all the trouble with? Read the manual.
Jason, Jen asked if you could spank her? I won't smack her hard enough?:shock:
Make sure the cable can travel smoothly in the tube. When they cut it to length it gets pinched a bit, I think you deburred it earlier right?
7 hours minus lunch = 6 hours and the axles are not mounted.:roll:
I guess we can subtract 2 hours for use of stunt spray and and general screwing around.;-):lol::lol:
