Jeckler
Let there be light!
Laziness and Cheapass had a fight. Amazingly, Laziness won. So I picked up a custom set of lights from RC LightHouse. There are 17 LED's in the set on 3 circuits. The switches are in the rear window. Switch 1 controls the taillights, 2 is headlights and running lights and 3 is the lightbar. There's a few things that aren't quite right. First is switch 1 is supposed to be running and tail lights and 2 is supposed to only be headlights. I'll fix that myself some time down the road. Then I'll need to extend the lightbar harness so the bed can tilt all the way back. Finally, I might redo the lightbar to kind of tuck that wiring in a little bit. I also wanted switch 1 to supply power to 2 & 3, but that wasn't done either.
I ran it a bit last night in the backyard and it works surprisingly well. The brightness of the running and tail lights is about perfect, not too bright, like it looks I have my foot on the brakes all the time. The headlights do a good job of lighting a path. The lightbar might need a bit of aiming however. I think I super-glued it to the roll bar a few years ago. Hard to believe I've had this truck for about 9 years.
Down the road, some sort of winch, which means a new radio too, unless I lock the transmission in 1 gear. Or, does anyone know of some gadget that will switch channel outputs? I swear I've seen something like that. for instance, some pre-determined stick action (2 taps up, or 2 quick taps back and forth) will make it change to the other output? I think the Tamiya MFU does something like this for a few of its functions, but I don't need that level of sophistication.
