Armistice
Like to use AF to change things up, so this time I'm going to run some leaf springs
Also had another person ask about them and seems people want to know about running leafs on Honchos
Started things off with the 66' Ford F100 body from Proline
Paint time!
Bought some D60 axle housings from SSD. AxialFest is allowing non-Axial housings, but must have Axial gears. My Scale Yota Axles won't allow that, so got the D60's. I think they look more Ford-esque than the stock Honcho axle housings
Leafs and hangers/ shackles from RC4WD for their Trail Finder
Replaced all axle housing bushings with Traxxas bushings. Regreased gears with Peak high temp red grease
Then it was time to start mocking up and installing the leafs
Teardown of the rear
Difference between the D60 (top) and Scale Yota Axles (bottom). Seems to be about 5mm's
Drilled out the forward hole for the shock hoop, and drilled a new hole for the front hangers. Rear hole I drilled out, but ended up drilling one in the actual bumper support for the shackle (which you will see in another photo). All holes at 1/8" drill bit
This shows where I had to drill in the bumper support. Also, the middle hole in the leaf is smaller than the 2 outer ones, so drilled the center out to 1/8". (I mangled one of the smaller leafs when the bit caught and tore it out of my hand, so be very careful, otherwise you'll have to prob buy another set for $30)
Could've stood to have drilled the hole a few mm's forward, but was too late, haha. It still cycles just fine. Only one leaf will be used in the rear
How it sits
Due to the amount of flex, the tires are able to laterally shift, but will just deal with it for now and fix if it becomes a problem
Shocks are RC4WD Superlift 100mm shocks. 90mm limit straps are from RPP. I took out the internal spring, drained the oil, and refilled with 30w Axial Honcho oil. It works. The rear doesn't bounce all over now
Teardown of the front! Due to the weight, I will run 2 leafs
Front install and hole drilling did not go as well as I had hoped, but did go better than previously thought when I did some quick eyeballing after finishing the rear
Was able to use the forward most hole for the shackle. However, my bumper crossmember is a bit in the way, and thus the leafs wouldn't cycle, so to counter that, I had to move the hanger rearward. Ended up working out ok, but positioning is not ideal
With my order of SSD D60 axle housings, I also bought the rear lockouts, cHubs, and knuckles. The knuckles are high clearance and are very high. Works great for coilovers, no so much for leafs...
Flipped them over, but they are pretty low. Can bend up the steering links for clearance. Due to articulation, it seems that keeping them high will have problems with the leafs getting in the way. I will evaluate this during testing
SSD makes pumpkin covers that look like the stock one(HD cover), but nothing in the grey to match my knuckles. Went with their solid angled version in grey, but turns out to be a bronze color. Might leave it... might paint it... Not sure. Also, supplied button heads didn't fit, so used the original cap head bolts
I wanted to know if 2 leafs in the front hurt my articulation. I can swing them out of the way and found that I gain no more than 1/16"... maybe a bit less when using 1 leaf. However, because my leaf is set up more flat than the rear, I'll prob keep the 2 just so I don't overstress the leaf. I'll post some articulation pics later
Steering servo is pretty far forward, so may spin the horn around 180º and set my Tx to reverse steering
Need to make up steering linkage. Found a pack of Revo rod ends and some 8-32 all thread and my taps. Might do those tomorrow
Need to get another set of shocks
Paint time!
How it sits
