Killr Chassis build
Looks pretty good!
If it were me, I would likely clip off the front bit of the frame rails to give the servo more room to move during articulation.
I see you have some lead weights. The bottom one looks like it is low enough to help with lowering the CG but I think the top one hurts your overall CG. I would go a long way to try to move that lower.
You might consider going with a system that has a smaller receiver to make positioning the components easier. I use the FlySky FS-GT5 largely because there are micro receivers available.
More pics!
