KillerBlackbird
A few weeks ago I bit the bullet and ordered an Axial Wraith Kit. Originally I planned on buying a RTR Honcho after driving a friends, but since they were out of stock everywhere at the time, I looked at the Wraith more and the more I looked at it - the more I liked it.
Last time I used an RC was about 20 years ago (Radio Shack truck I got for Christmas when I was a kid, haha) and I never was really interested in "racing" RC's, I just happened to stumble on a few scale crawling videos on YouTube and found it interesting. Slow and technical, cheaper than wheeling a 1:1 and easier to repair, not to mention if something breaks I can carry the Wraith out of the woods lol.
So anyway, the reason I bought the kit is for a winter project. Something to do in the basement when the snow is too deep outside. My goal is to have it running by April - just in time for the snow to melt.
I plan to make this more of a crawler, some parts I'll run as kit parts and replace as they break and others I will replace from the start.
As of now this is what I am running for parts:
Suspension/Axles:
-Vanquish Lockers (front and rear)
-Vanquish Knuckles in Gray
-Vanquish C-Hubs in Gray
-Vanquish Rear Lockouts in Gray
-Vanquish VVD Heavy Duty Axle (front)
-Vanquish Titanium Upper Link Arms
-Vanquish Titanium Lower Link Arms
-Vanquish Titanium Tie Rod
-Vanquish Titanium Drag Link
-Vanquish Axles (front and rear) in Gray
-Vanquish Smooth Differential Cover in Gray
-Vanquish Axle Trusses in Gray
-Vanquish Bearing Caps in Red
-Vanquish Shock Link Mounts in Gray
-Vanquish Panhard Kit
-Vanquish Chassis Mounted Servo
-RC4WD 110mm King Off Road shocks (no oil)
Wheels & Tires:
-Vanquish OMF 2.2 Beadlock Wheels (Silver beadlock ring/Gray front ring/Gray rear ring)
-Vanquish 475 SLW Wheel Hubs
-RC4WD 2.2 Super Swamper Irok tires
-2.2 Ripsaw foams in the Super Swampers
Transmission:
-SuperShafty Bomb Proof (Vanquish black aluminum housing, Hot Racing hardened steel gears, Hot Racing 5mm out-puts, SuperShafty "BEEFY" top shaft, SuperShafty "ULTIMATE" motor mount plate, Robinson Racing 56T/32P steel slipper clutch)
-12T/32P Robinson Racing hardened steel pinion
-RC4WD titanium screws (to mount transmission to skid plate)
Electronics:
-Holmes Hobbies BRXL ESC
-Holmes Hobbies Torque Master Pro 35T brushed motor
-Castle 10A BEC (set to 6V for servo)
-HiTec HS-7950TH servo
-Futaba 4PL 2.4ghz (4-channel) radio
-Micro cooling fan mounted in front
-All electronics and battery under front hood mounted on a custom aluminum plate
Lighting:
-Mad Dog RC double 4" Exo LED light bar mounted in a modified Exo roof light cage
-Mad Dog RC 2" LED light bar
-Mad Dog RC 1" Wraith rock light kit
-Radio Shack switches for each light bar group (3-switches)
-All powered directly off 3S LiPo
Body:
-DinkyRC Wraith Drop Box (black)
-Axial Exo Griffin radiator
-Freq-E-Skins custom RedBull outer skins
-Krawler Konceptz custom inside metallic RedBull skins
-Custom black plastic inner front fenders
-Hinged front hood
I started building some of the kit; here is what I have done so far:
All of my Vanquish Parts spread out:
Assembling my axles:
I also assembled my wheels and tires, I'm quite pleased with how they look. I vented each wheel like the Axial Rocksters are vented. Wheel face and lip is gray and the headlock ring is raw.
I'll run the R35 Ripsaws with full foam for now. I may change tires and/or I may trim the foam depending how I like the tires and sidewall flex. I also assembled the Axial shocks today and I built them with the softest setting. If they leak and are garbage I'll replace them, which I'll probably have to.
I'd like to do a brushed 35T motor but Im undecided if I should get a Tekin with the FXR ESC or a Holmes Hobbies.
I'm sure I'll have a few questions on things as I get deeper into it, I'll keep this thread updated with my progress.
Suspension/Axles:
Wheels & Tires:
Transmission:
Electronics:
Lighting:
Body:
-Hinged front hood
