KCRC - Kansas City Remote Crawlers -
I installed the overdrive mod tonight but didnt have shims. Feels ok but needs a shim or 3 to take up some of the slack for sure. At least the rest of the overhaul is done.
I installed my overdrive and with no shims there is less slack then there was with the stock setup. Are your gears smooth mine are a little ruff feeling I'm wondering if I needed more slack.
i installed a couple of the over drive gears in the mini's... i didnt use any shims and have very little play and ive also tested it through about 20 packs.. if you get it to tight it will bind and catch. and i also noticed a little rough just spinning the axle shaft by hand but once you put the wheels on and spin it it goes away and you dont even notice.
I think my gear mesh is to tight but I can't move the pinion gear back any farther. I'll be interested to see what other rigs sound like with this mod.
Thanks for the info, I had a major brain fart and was setting it up wrong. I finally figured it out earlier and now I'm trying to make some shims.
Can anyone help a :afro: out.......I need to come up with 8 Mini T soft springs (the silver ones).
If you have some collecting dust let me know, i'll take them off your hands $.
Kcrc/comp#4 - spring double points event !
KCRC COMP #4
Saturday may 21st
ADAIR PARK
Crawling starts @ 10.00 am sharp !!
SPRING
"DOUBLE POINTS EVENT"
looks to may-be a large turn out for this one,
so,
please try to show early to help out with setting up !!
HOPE
To See Everyone there !!
THX
KCRC
Not one but two Vendor Profile shout-outs on the home page from KCRC!!
Nice work fella's "thumbsup""thumbsup"
