I have been wanting one of these Vanquish VRD Carbon kits for a while. And when my impatient self says a while, I mean for the month or two since I regained interest in RC and watched a few videos of this truck. I want it all and I want it NOW! It's tough living life expecting everything to be like Burger King - "Your way right away". :lmao:
My plan is to build this chassis stock. I obviously have to add a body, electronics and wheels, tires and foams, but otherwise I will start stock. Then I will adjust or modify it from there based on how I feel it performs. I have a Fusion Pro 2300Kv on the way. I am anxious to try this all-in-one motor or 2-in-1 as they call it. The other possible option was an outrunner motor and a newfangled AM32 ESC with the Stubby kit and BTA servo, but that's a lot more added cost. I decided on the Fusion Pro because I love the idea of this motor and not having to solder or deal with as many wires and this is the more economical option. So I was being financially responsible with this choice...right :roll:
I do have to decide on servo as well. There have been a few new servo companies pop up during my absence from RC. Once you get a high-quality servo like Tekin or a direct power unit like Holmes Hobbies SHV500, you don't want to go back to cheap and weak servos. It looks like Holmes got out of the servo business though...
The kit box is tiny. I have never seen a smaller box for a chassis kit. Not including the body, wheels and tires saves a lot of space.
Le manuael. Vanquish manuals are typically pretty good, but they can have errors and sometimes their exploded diagrams aren't 100% clear about where spacers, shims and hardware are supposed to be installed.
Bag A - Front Axle
This is my first time building a plastic-axle Vanquish kit and I am seriously impressed by the axle housing. It feels really beefy. It is solid, stiff and has some weight too it. This should withstand a bunch of abuse.
Here is the front ring and pinion gears as well as the bearing carriers. (Originally I stated that these are overdrive gears, but they are not. This is the standard axle ratio. The overdrive comes from the portal gears.) The screws did not go nicely into the spool. My memory is a dim bulb, but I kind of remember this being an issue on other Vanquish kits. It's almost like the hole centers in the gear do not 100% align with the hole centers in the spool. Yes, I tightened it in a cross or star pattern. In the end it went together, but the screws do kind of grind as they are going in.
Also, I am not a fan of the plastic bearing carriers. This is mainly because you are threading screws into thin-wall plastic that holds the carriers and ring gear and spool assembly in place on the axle housing. If Vanquish offered these as an aluminum option, I would probably upgrade. The bearing carriers are aluminum in the aluminum axle kits from Vanquish.
Stout! The brass axle "weight" inserts seem like kind of a joke. They will definitely help reinforce the axle housing, but they are so thin that they do not add much weight. I would have weighed these if I had known where my scale is hiding. Does anybody know the weights of these brass axle weights that go inside the Vanquish F10 portal axle housings?
Axle mounted servo mount installed. It is kind of crazy how this is where we started, then we got super scale and went to chassis mounted servo (CMS) and now we are back to this. I wonder if Vanquish will offer an aluminum upgrade mount. The BTA mount is aluminum.
Now we haz front axle assembly. I like the thin tie rod and drag link as long as they withstand abuse and tumbles on the rocks.
The cast portal weights are also a nice design. I like that they are an integral portal cap and not tacked on. The casting is nice quality.
Quality builds are always nice. Things go together as designed, fit is nice and tight, and the assembled product feels high quality. This makes for a fun build. I am looking forward to the rest of this kit.
Bag A - Front Axle
