Yeah they're feeding me a bunch of BS hoping I'm a noob that just says OK I'll try thread lock to fix your screw up.Geniuses.
It's too bad that this build has these issues putting a bad taste in your mouth. I hope they all get resolved easily for you, as the TF2 platform is pretty great and you will have a lot of fun with it. Like Nate said though, its due for an update.
I installed a round head screw before I even posted that photo. That's not the point.I'm telling you, just use a 3mm socket head screw for a drive pin...
Their CS is ok, but they do not speak english natively and take 4-5 emails to get anything done.
I have a couple of questions.
1. I have one big helper under the main spring in the front and in the rear I just have one big helper above the leaf. The back of the truck seems to sag in the rear.
How many leafs are you guys running?
2. How much body modification, if any, is needed to fit the Tamiya Hilux round headlight grille?
The body is just setting on the truck and I'm sure it's not level. But if you look at the picture without the body it still seems to sag in the rear. That's even without the battery or body being on the truck.I'd be surprised if the sagging stance was just related to the helpers, esp. given how light the back end is. I'd guess there's something else going on with your stance. There are several possibilities, including bed pushed too far down the body posts, rear leaf shackles snapped into the locked position on full compression, front leafs still arched and rear leafs flattened out, etc.
Once I drive the truck I'm sure I'll get an idea of what to adjust. At this point I haven't driven it so my starting setup is just a guess. I'll adjust as needed.My two standard WB trucks run red leafs with full-length black helpers (black leafs with eyes cut off) and medium helpers underneath. One of those has short helpers above the red leafs, one doesn't. My LWB runs the black leafs with medium helpers underneath and short helpers above the leafs. The reds are more compliant, but you have to be judicious when in binds because they warp more easily. The LWB has a much stiffer ride, but it's still very capable with appropriate adjustments to driving style and lines.
That photo is very helpful. There's barely any difference.Not much. The Mojave 2 front fenders have a taller notch-out for the side marker lights than the original Mojave and Tamiya bodies have. You'd just need to add a bit of styrene to fill in that gap. Here's a side-by-side of the Mojave and Mojave 2 grills showing the difference:
RC4WD is still insisting blue Loc-Tite is the correct fix for the driveshaft to transmission pin screw. All I can say there is WTF?!
Just because it works doesn't mean it's the right fix. It's a flaw that the pin screw does not have anything to tighten against.I’ve been running all of mine this way for years and never had a problem. Once the thread lock sets, the set screw won’t go anywhere unless you want to take it out. This is really a non-issue. “thumbsup”
They are also insisting I send the trans back and wait for another trans. Well the trans is already installed. And all I really need is an output shaft or a better driveshaft. And I shouldn't have to wait to use my truck because of their **** up. Good companies, and I've dealt with plenty, send the replacement part and then have you ship the defective one back in the same box.
They are sending out one replacement shock based on the photos. They said there's need to send that back. First smart thing they have said. I just wonder if it's coming from the US or from Hu Da Fook Knows in Asia. As far as the junk on the other shock shafts I was told to wipe it off. Apparently Taiwan doesn't do housekeeping.
At this point **** RC4WD! They are quick to respond to emails, but their customer service is useless otherwise. RC3WD - barely a step above Integy. I bought the TF2 from Tower Hobbies. I will just email them if I have any other issues. They are quick to respond and rectify issues even with products from other companies.
I got my GMade RSD shocks. What weight of shock oil should I start with?
Sent from my SM-N910V using Tapatalk
Why light? On a leaf spring rig the shocks dampen the bouncing and oscillations of the leaf springs. I don't think light weight would do much to help this.As light as you can and have them not leak.
It seems lots of people have quality control issues with their RC4WD kits. I knew this coming into it. I was hoping they would have changed. Apparently not at all.Curious to see how you trim the body for the tires.
I feel your pain with this kit. I got mine built and its fun now. But during the build process I had issues like you had. I didnt bother to deal with their Customer Support. I just fixed it like I would in the field. This did, however, build up a lot of frustration. Which lead to a Titan 12T and 3s Lipo bash session. Go or Blow. It decided to go and not blow so there is that I guess...
I don't have an answer for you. Sorry.My TF2 LWB chassis kit just arrived yesterday. I was collecting some upgrade parts before I start assembling including the Bowhouse crossmember parts. I wanted to install the GII front shock mounts but I see they are out of stock everywhere. In reading all the many TF2 threads I read somewhere that the Hot Racing SCX10.2 shock mounts will work on the TF2 frame but I have not been able to confirm this. Has anyone installed the HR SCX10.2 front shock mounts on a TF2?
I don't know that I have rear sag. I've never mounted the body correctly.Hey Jato, did you ever solve your "sagging rear" problem (no pun intended!)? I ended up putting the springs back in the rear shocks to get it to not sag, and I am running all of the leafs! IIRC there is another post on here about the rear sag.
