i try to keep the input shaft on my locker as short as possible,
just long enough for a drive cup or MIP drive hub to fit on - right up to the locker itself.
seems when you have the out put shaft longer than necessary it wants to bend faster - 5 or 6mm !
look at the stock EXO locker - drive cups agents the locker
(right side) MIP drive hub with a longer out put shaft - not good !
(left side) stock EXO drive cup - no out put showing ! - good
keep them short as U can - should have no problems with dog bones popping out ! - & a lot less chance of bending the locker out put shafts !
only mods i did on the MIP drive shafts - was to cut them down for more shock clearance. stock MIP lengths
& just a side note !!
if your thinking about a BM locker for the Yeti & if it is set up like a stock EXO front locker ?
we may/will need these drive cups for the BM locker to run dog bones/CVD's on the Yeti ! - i believe !
for 5mm shaft lockers & dog done/CVD's front drive shafts
just trying to help out U - make us the best front locker out there !! "thumbsup"
the DmG !
