Idaho Crawler Picture Archive
My two current rigs...
SCX10 based LR3 mall crawler (must be from Eagle, right?):
Still working on the lights and I have a couple scale items headed my way.
And the DNA slingshot Axial rig:
And a shout to my first hobby class truck
This is my Duratrax CC (1/14) I picked up from HT a little while back. Got the ARTC version for under 50 bucks!
Wheelbase is at 12.5" (at ride height, compressed 13"max)
Tires and wheels are stock, customized.
Links are home made. Traxxas shocks off stampede.
Running a losi micro 12t esc to the dual stock motors.
Traxxas 4 channel reciever. futaba s3003 standard servos front and back.
Duratrax stock body.
My goal was a LOW COST, capable crawler.
Oh and the lights too!
Love some of the rigs on here! You all are making me want to spend some real money and build a scaler!
this is my first crawler and my fist attempt at flames. i will be adding more scale stuff as time goes on.
it is a stock Axial Honcho
ESC: Tekin FX-R
Motor: Tekin 35T
Servo: Hiteck 7955 TG
radio is a skyion dx pro with 3 channel reciever works well
i have pro line wheels and tires on it now with wights and extra 240 grams in each wheel really makes a differents.
wheelbase 12.3
width 9
height 5.9
ground clearance 2.7
weight aprox 10 lbs she is pretty heavy
pictures are in the back yard glad i made that burm and stream
My first and only crawler so far. I know it looks like a stock CC but I have made some changes. Longer bent lower links to level out the axels. Machined new steering knuckles which corrected the steering geometry. Locked out the rear steering. Added the Hitec 645mg and alum tie rod. Wheel base is now right at 10". Went with a Tazer 15T esc so now I run one 7.2 stick. The motors are the next step up from Dura Trax 8500. I have a Chevy C10 body I'm about to paint up for it which should make it look better. I also have a set of rover whites but I can't pull them till I get the gear reductions from RC Rock Crawling. The plan is to be right at 12.5" wheel base when I'm done.
Hoping to start a scaler soon after I get this one to a point that I can compete.
Ok this is my newest crawler.
Based on a Redcat RS10
Narrowed chasis
switched t stick style battery
WB 12.5"
Custome battery tray and component tray
Rovers w/ over sized memory foam
Proline wheels
Hitec 645mg
locked out rear steering
Axial alum green steering knuckles
TQ 2.4GHz 4 channel radio (prepping for a dig switch)
Now I'm ready to play.
Truck Base : Venom Creeper
Body: Stock
ESC: HobbyWing
Motor(s): Tacon 1200kv brushless
Servo(s): Tower Pro MG996
Trans: Venom
Axles: Venom
Tires: Losi Rock Claws
Wheels: Venom Beadlox
WB: 12.5''
Overall Width: 10.75''
Diff clearance: 1.5''
Center Chassis clearance: 3''
Overall height: 7 3/4""
Weight: 5.2-7.2 lbs (depends on wheel weights used)
Pics here....
http://www.facebook.com/photo.php?pid=271818&id=100000178690279#!/photo.php?pid=320858&id=100000178690279&fbid=127038060645483
\m/>_<\m/
bronco hpi body with stock inter. from scx10
stock scx10 with 2.2 flatirons with ofna stadium truck shocks lifted to clear the body
tuber is custom made, revo shocks 12" wb
stock axial axles, and tranns hpi tires with jc con. rims
brushless speed control with out runner motor
28 leds to run at night (looks like a spaceship at night)
i dont know if im supposed to do this but here is some comp pics. mine is the yellow bug.
