R/C Ginker
I wonder if traxxas will offer the 79 Blazer with the clipsless system everything from the K10 fits with one modification and it’s like they planned for it. If you look at the bottom of the K10 body you’ll see 2 sets of mounting tabs. One set used for the K10 and the other about an inch forward. If you cut the back section off the remainder works perfectly for the blazer. The second to last photo shows the part numbers used to convert the Blazer body to clipless. You’ll also need some double face tape to attach the back pad to the body. It’s was a very easy conversion. Next step is to figure out what to do about the open holes. I have a few ideas. What are your thoughts?
