Hybrid
pete959
US
this will be slow going but i bought to get my feet wet
LIFE IS GOOD
Ok got a few question i am going to go back to leaves at all 4 corners will the revolver type shackles work on bruiser chassis next how strong r the ltl axles as in will they hold up to 1.9 steel wheels with 3s power if i ever even get that far this was mostly bought to see how much i like leaves and to try my fat fingers at scaling
LIFE IS GOOD
The tlt are decent on strength, 3S power might be to much for them to handle. I think 2S will be a little better.. Leaf springs is a hit or miss. But to run leafs in the rear, you would have to make an adapter for them to mount to the axle.. Most people running a bruiser frame run the setup you have already, cause to gives good flex... The revolver shackles will work on a bruiser frame.. I was going to pick up a set for one of my bruiser's..
Sent from my 2500HD
I am going to start tearing her down soon and rebuilding it probly Saturday night
LIFE IS GOOD
So it begins
chassis stripped and ready for sand blasting then primer and paint going to do a gloss chassis and flat black body
LIFE IS GOOD
Ok i will finsh painting chassis tonight then srvice my ascender and i got a question for u real tamiya nerds where can i get a stepside yota bed
LIFE IS GOOD
LIFE IS GOOD
You mean the old OG Hilux bed.. You have to keep an out on eBay.. It took me a year to find mine..
Like this one
Sent from my 2500HD
I knew u would have it yea i read that they r very hard to find
LIFE IS GOOD
Well she is now a pretty flat black and i got her to run for a few min my motor gear isnt splined right but that will be fixed also bent my rear springs but that is my fault bad mounting but she will be up and going soon
LIFE IS GOOD
