So the first rig to get me into crawlers was a Tamiya CC01 with the FJ40 body. It was cool but not stout at all and recently I tried to beef it up a bit but decided I'd rather just build another rig as a sort of tribute to it.
Enter the GCM Racing CMAX chassis. Ever since I've seen this scale transmission I've been drawn to their kit. I really liked the idea of having it fully leaf sprung unlike the RC4WD offerings (plus I've seen their products and folks struggling with them)
I used the CMAX basic started kit since I was also using TMX front axle which has the narrow leaf mounting points (the leafs sit under the frame rails instead of outside of them) this gives the tires more room for more angle which is a bit more important when using bigger tires.
The other items from GCM Racing included their TMX axles and TMX axle hardware kit, NC Yota 152 Front Leaf Spring Mounts, CMAX Rear Leaf Spring Mounts, CMAX Tiny Shock Mounts, TMX Steering links.
For the Leaf springs I went with the Tamiya leafs springs #9808091 from their High Lift I believe (recommended by GCM).
Shocks are the EXC 213000 (also recommended by GCM)
After feeling how heavy the body was I ordered up some SSD front Weighted knuckles for the Ascender (they fit the TMX axle since its loosely based off the Ascender axle) and the SSD rear axle weights which luckily fit with 1.5 wheels (SSD D holes) using PitBull Rock Beast 1.5's (3.85" tall)
You can see above that the leafs have the RC4WD pinion angle shims, but after use the Leafs have turned into an S shape so I need to remedy that. I'm thinking that adding a leaf above and below it might help it to hold its shape, and the other option would be to link the axle to keep it located properly but I'd like to avoid that if I can.
I made some brackets so I could use the extra chassis that I cut off the rear as a body mount.
Rare earth ring magnets were used to attach the body along with the tips of some left over body posts to help keep them centered, I drilled a hole through the center of the body posts so I could fasten them to the brackets. I used E6000 to glue the magnets down and packing tape (with and x cut in the middle to allow the post to pop through) to prevent the glue from transferring to the other end. Those were all tips from the guys at GCM Racing and they worked out great. Also they said to leave the packing tape even after its dry as the E6000 tends to stick back to itself if its allow to rub against itself.
the rear body mount was just a small piece of angle aluminum (to the left of what I'm holding)
Above you can see the wiring, it was a challenge to fit under the interior, it had too be spread out to work.
My first experience with styrene was a good one, I liked working with it. I made the battery tray and electronics trays.
and the rear most tray
instead of using the rear chassis brace as a upper shock mount I made a bracket to raise the shocks a bit.
Using the SSD knuckles meant putting the steering links below the mount on it and on the other side using a 7mm spacer to get the other side inline. this actually worked better than with the GCM knuckle which hit the frame rail under compression, now it clears even better.
You can see I've bent the upper steering link for clearance
The electronics I went with are Holmes Hobbies Crawlmaster 13t (reused from another rig) a Holmes Torquemaster ESC, Castle 2.0 BEC, Spektrum reciever, HiTec 7950 Servo, and RC4WD cruiser light kit.
More to come later
More to come later
