Panther6834
I've been searching for this formula, but have been coming up empty. Honestly, I think there's are a LOT of others wanting/needing this info. Without this very important piece of information, it can be near-impossible to determine what tooth count one needs for the motor's pinion gear. So...does anyone know the formula for calculating the final drive ratio...with, and without portal axles?
I'll give an example. Starting with an AX10-style 3-gear transmission (say, 56T spur), using the standard 30T/8T ring & pinion gears in the axles, with portals having 0.875:1 in the front, and 1.14:1 in the rear. Another example would be the same transmission, and standard axles, but using the 27T/8T OD gears in the axles. In both examples, even if I had the formula, I wouldn't be able to calculate the FDR, as I have no clue what the standard AX10 3-gear transmission output ratio is.
This is a formula that a LOT of people could use...but, at the same time, a formula that few people (relatively speaking) seem to know.
~ More peace, love, laughter & kindness would make the world a MUCH better place [emoji1690]
