DadCanyoufix?
Haven't officially made a build thread for this little guy yet as I got it out of state and originally thought I would leave it stockish :roll:. Instead of starting a thread for aftermarket wheels, tires, bumpers, shocks and such, I figured it could lay low. I had a blast with the thing at AxialFest 2018, ran it over 1000 gates with no issues at all. After AxialFest I figured it would best serve me as a guinea pig for new ideas or new to me ideas that I might implement to other builds. I'll still list on the basics of how it started.
GDS Wheels
Scalerfab Front Bumper
Goodyear A/T Tires Purchased at AF18
Light Buckets from old honcho body set
Pro-Line Classic Interior
Samix Panhard Bar and Tie Rod
Axial Universal Shafts
Aluminum Servo Horn
Savox 1230SG
Warrior Armor Sliders
Came with Metal Gears in Trans
Gmade 93mm XD Shocks from Parts Bin
Hot Racing Overdrive Gears in Front
On to the title of this thread, Leaf Springs. I had done a few searches here and there as I want to put Leaf Springs in the rear of my Ram to further mimic my daily driver and now I want to make a dingo 2.0 fully leafed for my wife and daughter to join in on the fun. So, guinea pig, you're up. Ordered a full Leaf Spring kit by G-Made(they have the U-Bolts, I like that) and figured I could test it out on the honcho. To work out the kinks as far as fitment goes, see what parts I can find and or fabricate and test spring fade and durability.
I found everything was pretty much in the kit except the perches for the springs to sit on. While I have been told a few companies make them, none of the products I saw fit what I envisioned working best and fitting my desire to have both dampening shocks inside the leaf springs and on alternat sides of the axle, one forward, one aft. Soooo, I made my own. Did a little sanding on the springs, put some spacers in the rear of the chassis, and drilled some holes for the forward hangers. Boom, was right where I wanted to be. Couldn't believe how well everything worked out in 2 days(few hours each day).
First, a few pictures of the set up focusing on the spacing out in the rear of the chassis, then on to the initial test on the curb outside my front door. This weekend I plan to take the truck to a creek I was clued in on by an old friend. Have been using it to test suspension travel and link stability/durability as it has varying obstacles and a ton of big transition rocks to get all those sweet Leaf Spring flex shots ;-).
Opinions Welcome! If all else fails, hopefully this will add to the leaf spring search results for others so they can grab more ideas when thinking about joining the Leaf Spring club. Pretty fun so far!
I'm not really sure how much flex/articulation I should be getting from a leafed rear and linked front, but in my opinion, if the springs fade a little and yield just a little more in time, I would be pretty happy with the results as it would be pretty close to the stock linked set up. If they do not fade, I have options as I am currently running all 3 leafs that G-Made includes per corner. I feel I'm well aware flex isn't everything, I have a couple trucks that get a little less than a tire's height of travel before I float a tire. I just want to maximize performance before implementing this to my Ram's rear and starting a Dingo fully leafed build.
GDS Wheels
Aluminum Servo Horn
Savox 1230SG
