I just received my new Hobbywing QuicRun 1080 in the mail and thought I'd post a few photos for those of you that are curious about this new self-entitled "Game Changer". Let me start out by saying I've owned a few Castle Sidewinder 3's, the stock Vaterra Ascender Dynamite ESC, a Castle Mamba Max Pro, and a Holmes Hobbies BRXL (Waterproof). I bought this unit because I'm hoping I can really avoid a BEC as advertised with its 7.4V capable internal BEC, it's waterproof, it's small, and it's cheap!
I ordered this ESC from Amain Hobbies, where it retails for $41.99.
Features:
- Water-proof and dust-proof, suitable for all weather races.
- Small size, with built-in capacitor module.
- 100% Waterproof
- 15 programmable parameter items
- PWM Frequency: 1K/2K/4K/8K/16K Adjustable
- Freewheeling (DEO) capability
- Drag brake rate in 9 levels (adjustable)
- Electronic switch
- Aluminum case for great heat dissipation
- Great current endurance capability.
- Great built-in BEC output capacity.
- Automatic throttle range calibration, easy to use.
Multiple protections:
- Over Voltage Protection
- Low voltage cut-off protection for battery
- Over-heating protection
- Throttle signal loss protection, and much more
It comes in a nice little package wrapped in plastic
Untouched contents of the box
There's a few cool things in the box, including:
- Programming card
- Decal sheet
- Two sided tape
- Red and black heat shrink tubing
- Instruction Manual (one for ESC, one for Programming Card)
- Two cable ties
- servo extension
The programming card doesn't feel as cheap as I expected (although it's far from premium), and looks fairly simple to use
The ESC itself seems like fairly decent materials were used. The wires are flexible silicone coated, and the on/off switch has a decent length of wires to it for placement
I plan on putting this in my new SCX10 II paired with a Traxxas 550 can 21T motor. I've heard great things and will post updates once I get it installed and running. I'm hoping that it is silent as others have indicated, I can't stand the beep sounds on the sidewinder 3. The Holmes BRXL has silent mode and it is truly a different experience trailing without that annoying sound.
For $42, I'm very happy with my purchase so far. The materials, even on the packaging, have an unexpectedly premium feel and I have high hopes for this nice little unit!
Features:
- 100% Waterproof
- Electronic switch
- Programming card
- Decal sheet
- Two sided tape
- Two cable ties
- servo extension
