Whats_a_dickfer
::EDIT:: Decided to rename this post and make it a build log
First run, I'm impressed. The steering on this truck is insane! I thought my FCX had a tight turning circle but dang, this something else. Mods so far are Treal aluminum beadlocks with brass rings and 64mm Injora hyrax clones borrowed from my FCX, moved the rear shock tower forward by one hole, threw some little hair tie rubber bands around the shocks to force full droop, ditched the roll bar, and installed tail lights.
The wheels and tires turned out to be a perfect fit. No rubbing at all. Should have remembered to pick up the crawler gears when I was at the LHS, but oh well. The slope in the first pic is really steep, like hard to walk up, and the F-150 pulled some of the trickiest lines no problem. Well, not quite "no problem" but it made it! The hill is really steep and covered in loose dirt so the wheelspeed from the medium gears probably helped.
